Electronics DPDT dual cathode setup?
Discussion in 'Modding' started by Floydian, 20 Aug 2002.
  1. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    Is it possible to switch between two cold cathode bulbs by using a dpdt switch inbetween the bulbs and the inverter?
    Like:
    Code:
          bulb 1 -
         bulb 2  -
    to inverter -
    On/off/on type? They wouldn't be powered at the same time, but switching between the two.
    I'm not sure of the right type of switch, but would you need a special switch since its higher voltages? Or is there any dangers in doing this :eek:
  2. CrazyJester
    CrazyJester What's a Dremel?
    18 Jul 2002
    you only really need a SPDT switch. I don't think 1000v or whatever a CCFL is at will jump the gaps in one, but you may want to just hook it up and try... you'd do it like this:
    Code:
                    SPDT
                     o------- +CCFL1- -----|
             +  -----o                     |
    Inverter         o------- +CCFL2- -----|
    However, http://www.pcconsultant.com/lampfaq.htm says
    "Can I hook up more than one lamp to an inverter?
    No. Each lamp requires it's own inverter. Also, don't plan on using a selector switch on the lamps to connect multiple lamps to one inverter. Even though a selector switch would let you have only one lamp "active" at a time, the voltage levels are too high to successfully switch them using a selector switch.
    Bottom line: Each lamp requires it's own inverter, period. With a little ingenuity, you can conceal the inverter so it doesn't show."
