Scratch Build – In Progress " Dragon Desk" ( build in progress )
Discussion in 'Project Logs' started by Gas_designs, 3 Jul 2015.
  1. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Today I begin to make the rear holes of the radiators, where will waste 2 :: :dremel:
    Small and simple idea, to smooth the circles :: :D
    And finally mount the radiator ::
    Now the two radiators are united, skipping the power supply, with rigid pipe, so I am created a template of the curvature :: :)
    Now I connect them with its fittings ::
    ............. :clap: :clap:
  2. Icelander
    Icelander Member
    3 Mar 2015
    slick bend around the PSU ;)
  3. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Hi guys :D
    Today it mounts the grids 360mm Phobya and since the 3 fans are distant 20mm from each other, I have to make holes :: :)
    Now you have 2 buttons 25mm:: :D
    ................ :dremel:
  4. Gas_designs
    Gas_designs Member
    29 Sep 2014
    In the meantime a little sleeving... :D
    Now after taking exact measurements , start to make holes for the bulkhead :: :thumb:
    Now step to the vertical panel of the mobo , even here the holes of the bulkhead , and the screen of the liquid temperature , and the window for Strix :: :dremel: :dremel:
    ..................... :thumb:
  5. Matrix74
    Matrix74 New Member
    16 Aug 2015
    beautiful buttons ......., I have to take them too but I am undecided on color and color of the LED must have.....:duh:
    I follow you
    :clap::clap::clap::clap::jawdrop::jawdrop::jawdrop::jawdrop:
    Good WORK......!!!!!
  6. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Hello guys ... Today we start with a layout , to mesh power supply:: :clap:
    Once covered the area with the paper, proceed to give a nice pass from vinavil:: :thumb:
    So look 24H::*
    Now that thelayout, it is hardened for good, proceed with the 1st pass, with a little bit::*
    Then go climbing with the measures of the tips::* :thumb:
    Removed the burrs , it introduces itself:: :D
    .................... :dremel:
  7. Matrix74
    Matrix74 New Member
    16 Aug 2015
    :clap::clap::clap::clap::thumb::thumb::thumb:
    and this is the air intake in the shape of flower..............
  8. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Here we are, now a chore easy easy:** :dremel:
    Aluminum thread M 4X0,7
    Allen Steel::* :D
    And finally fixed it all:**
    ................. :dremel: :dremel: :clap:
  9. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Meanwhile came the sister, because she was lonely ..... :thumb:
  10. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Now it's the most fun, position the 2 lower grilles of phobya, under the desk , in the air inlet to the radiators ...
    Now I take the imprint of the hexagons grid..... :)
    And then slowly , I take all their centers .... ready for drilling ..... :duh: :duh:
    ................. :clap:
  11. Icelander
    Icelander Member
    3 Mar 2015
    wow. have fun filing that my man :thumb::dremel:
  12. Gas_designs
    Gas_designs Member
    29 Sep 2014
    There will be fun ... :lol: :lol: :lol:
  13. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Here we are guys, after a little break, because night work. :rolleyes:
    I begin the adventure of 244 holes, with a tip from 6mm to start.. :D
    Some chips ... :dremel:
    And now a nice clean.
    Now we start to make holes with a cup 16mm, with the new drill of Bosch, as my old Valex has abandoned me . :idea:
    ............... :clap: :clap: :clap:
  14. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Now we begin the work more complicated, I start with a first pass with a cup 16 :dremel:
    Some cutting oil , does not hurt :)
    Chips - chips , chips and more :lol:
    And yet chips :lol:
    And after 3 hours :clap:
    A nice clean, and tomorrow will continue , with smaller holes
  15. ajangusjames
    ajangusjames New Member
    26 Dec 2011
    This looks incredible. You have my attention.
  16. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Thank ajangusjames. :thumb:
  17. OmightyOne
    OmightyOne Member
    7 Nov 2011
    Very nice, jealous of all the WC parts!
  18. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Hi guys .... :thumb:
    n this step , the aluminum hole , to fix any HDD 3 , and on the shelf 3 SSD :dremel:
    I put the rubber to the vibrations.
    Now it's up to ssd. :dremel:
    ........... :thumb:
  19. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Fixing the grid Phobya. :thumb:
    Now the holes Laser Guide, I make a thread, and insert the allen steel. :D
    Some wing nuts. :dremel:
    Finally fixed the hatches with butterflies, so 'to be comfortable, and no tools for disassembly. :naughty:
    PS:
    A little helper for precise holes. :clap:
  20. Gas_designs
    Gas_designs Member
    29 Sep 2014
    Today day soft......then mounting radiators and fans.... :thumb:
    ........... :clap:
