Scratch Build – In Progress dragon eye :)
Discussion in 'Project Logs' started by samfgr, 13 May 2012.
  1. samfgr
    samfgr techno : my life
    29 Jun 2011
    here'S my first modding ever it's a scrapbuils as you can see give me some feedback (sorry for the picture quality: iphone quality :p)
    I started by doing plans on google sketchup:
    then I chose tne material i'll use:
    then, came the disassembly of the two computers i'll take the parts of:
    then came the cuts and painting:
    then, I did my two desing with paint:
    then I did an extension somy iphone dock(i'll explain later) and my two hdd could fit over my mother board :
    I did my extension to fit this :
    and this:
    it'S a iphone dock on a little custom made drawer with an independant audio sound to the speakers wich can be changed to the computer with a switch, i'm really pround of that what do you think about that?
    so the final results are :
    anyway thaks for watching i'm lokking forward to your comments
  2. bulldogjeff
    2 Mar 2010
    Ermm...No pics at all !
  3. samfgr
    29 Jun 2011
    I linked about 15pictures... What could be the problem?
  4. m K o
    m K o What's a Dremel?
    25 Sep 2005
    I doubt that dropbox images can be used like that.
  5. samfgr
    29 Jun 2011
    what would you suggest me then?
  6. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    You can upload them here, go to the User Control Panel, then albums, they need to be edited to about 800x600 i think,
    or
    you upload them to imageshack or a similar site where your image sizes can be anything (think of peoples connections though, don't have images 5000x5000 pix).
  7. samfgr
    29 Jun 2011
    ok thanks I just understood how to do it so I redid my first comemnt :) take a look :)
  8. samfgr
    29 Jun 2011
    just got my grade about it in school : got 97% !!!!! but for sure I won't stop modding!
