Dragon's Anger ( WOOD )
Discussion in 'Project Logs' started by infoworx, 30 May 2004.
  1. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    i'm with you, no offence but those cuts are SO HAGGARD its not even funny
    if you want a tight looking rig when you get done your gonna have to try a little harder, and be patent.
  2. EdHunTer
    EdHunTer What's a Dremel?
    8 Apr 2004
    sorry to say this but the holes look like crap otherwise i second that it has potential. i would suggest getting a dremel (if you don't already have one) or a cheaper so called dremel copy put in a sanding head and even out all those holes.
    The Dremel is your friend! :D :dremel:
    also since you have windows on your case i'd suggest you get rid of the wire couplers holding the CPU heatsink and the gpu heatsink. find a cleaner alternate to instal them
    for the cpu get a replacement p4 retention clip for your mobo (avalible on ebay cheap)
    keep it up and don't let other ppl discourage you. the first time is always the hardest :thumb:
  3. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    An easy fix for uneven fan holes is to get a fan grill that will cover the cuts. You can pick up some fan grills for no more than 3 bucks a piece.
    JEEVES
  4. infoworx
    infoworx Banned
    11 May 2004
    Thanks for your suggestions guys. I've got many fan grills .. i just didn't install the back fans yet until i finish my fan controller. I will buy a Ferm Dremel in summer... i've got a sucky one at the moment
