News DRAM prices continue to fall
Discussion in 'Article Discussion' started by Lizard, 25 Nov 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. wyx087
    15 Aug 2007
    yay, time to start saving up for some nice 4GB per stick modules. 16GB for under £200 anyone?
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Good, i need to replace the 2gb stick i bought in error and never got round to replacing.
  4. Ryun
    Ryun What's a Dremel?
    28 Apr 2009
    And here I was thinking I would have to settle for 4GB on my next build. The way things are going, I could very easily decide to purchase 8GB.
  5. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    It's one way to keep upgrade addicts buying, that's one certainty. Had my eye set on a laptop but if memory stays this cheap, it'll be hard not to stay with a full-sized new build.
  6. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    What is the best value/price/speed 6gb triple channel set to get at the moment?
  7. javaman
    javaman May irritate Eyes
    10 May 2009
    Might pick up 2X4gb sticks for a new build. Wasn't planning to replace my mobo and inevitably jump to DDR3 until the end of next year after AMD and intel had their new products out and prices stabilise, tho if the market is gonna be volatile it would make sense to invest now.
  8. memeroot
    memeroot aged and experianced
    31 Oct 2009
    upgrade ahead
  9. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    I'd say 1333MHz or 1600MHz if you plan on overclocking.
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Our man in Taiwan was spot on with his info :)
  11. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Hopefully this means I can 8gb my laptop without breaking the bank.
  12. dactone
    dactone dact-one
    26 Apr 2010
    it's dropped alot since i last bought ram 6gb dd3 for 86 pounds i bought 5 months ago for 140 .
  13. halcyondays
    halcyondays What's a Dremel?
    10 May 2010
    having got caught out before it's almost worth buying some ram to have in stock at these prices, no upgrade planned but it's bound to return to high prices....
  14. murraynt
    murraynt Modder
    6 Jun 2009
    Looks like 8gb is possible for my next build :D windows 7 eats up 4gb pretty fast.
  15. Phoenixlight
    Phoenixlight What's a Dremel?
    29 Oct 2010
    What does North Korea being a dick yet once again have to do with random access memory?
  16. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Time to order another 16 Gigs!
  17. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Thanks for the memory.
  18. Tangster
    23 May 2009
    Makes the region volatile. War in that area means that fabs and transport is under threat so speculating t**ts prebuy in huge quantities while the price is still low and force the price up because they predicted a shortage.
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    Question is, when will 4GB sticks of DDR3 ECC RAM be cheap!?
  20. KidMod-Southpaw
    28 Sep 2010
    Well, I could gram myself 8gbs now.
Tags: Add Tags
