Other Drawing scanning
Discussion in 'General' started by Revil0, 6 Sep 2018.
  1. Revil0
    Revil0 What's a Dremel?
    21 Jan 2011
    Hi all
    I have some large (A0) technical drawings that need scanning but am having trouble finding anywhere with a large flatbed scanner. Tried a couple of places with roll scanners but there's been too much distortion for the scans to be useable..
    Does anyone know somewhere in the Cambridge area or that takes postal order which won't cost the earth?
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
  3. RedFlames
    23 Apr 2009
    Also iirc anything that size is going to be that type of scanner. Not looked at large format scanning since uni but from what I remember flatbeds tend to top out at A2.
  4. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Op is after flat bed scanning.
    Tbh your going to struggle to find one nowadays, Asking around your local universities/museums would be your best bet.
    If the drawings are dimensioned it will be faster to just redraw them in cad not to mention more accurate. (printed scale drawings should never be trusted especially old ones)
  5. Revil0
    21 Jan 2011
    Yeah, I was there this morning!
    They're hand drawn plans of musical instruments which are rather more complicated to reproduce, thanks for the suggestion :)
  6. Gunsmith
    23 Sep 2005
    ah i missed the flatbed part. yeah i think you're gonna struggle to find a flatbed that large tbh
  7. Archtronics
    27 Jun 2006
    Just a thought you could try photogrammetry and create 3D model then set up a camera to get a 2D view.
    RedFlames likes this.
  8. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
  9. RedFlames
    23 Apr 2009
  10. Arboreal
    21 Jan 2011
    That should work well if properly set up.
    One of my clients has her oil paintings reproduced that way at a copying company near me set up by an old friend. He has been doing it years and has the polarised lighting set up perfectly.
    Over time he has moved from medium format film to MF digital and now to a high res Nikon DSLR, as it is just as capable as any of its predecessors. Camera alignment and parallelism is obviously important, and with a proper rig isn't a problem. That's the only way that I can see it being done well.
  11. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Can't you scan multiple sections on a flat bed and stitch them together afterwards. We do this quite often for clients who want art prints reproducing and with photoshops alignment tools, you can achieve an almost perfect reproduction.
  12. Gareth Halfacree
    4 Dec 2007
    The problem with technical drawings is that "almost perfect" can mean the difference between functional and non-functional. (I've used that method with an A4 scanner I got for £1 at a car boot, to scan larger schematics - and it works pretty well (PDF warning), but I'm not worried about whether a given line is a few millimetres shorter or longer than it used to be.)
  13. Modsbywoz
    14 Oct 2009
    I whole heartedly agree, if a perfect reproduction is required, tiling multiple items in photoshop will not be suitable.
    In past experience, finding an accurate flat-bed scanner larger than A2 is extremely difficult or incredibly expensive.
