Modding Dremel 8100 Review
Discussion in 'Article Discussion' started by Meanmotion, 5 Mar 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    Cordless tools are generally useful for situations where you can't easily bring beefier power to bear; outdoor, mobile, home DIY (garage or motor tinkering area may not be wired for power) etc. I fully agree that corded is the way to go for the computer case modder. But when I'm e.g. working on bodging something to fit on one of my bikes, it's much easier for me to bring the tool to the bike than the bike to a power point.
  3. law99
    law99 Custom User Title
    24 Sep 2009
    Mobile and supplementary use in addition to corded. Two thumbs up.
  4. asura
    asura jack of all trades
    22 Apr 2009
    I don't know what their estimated mtbf is, but a couple of cordless dremel's I've had lasted no more than six months of daily use. Continuous load testing and charge/recharge cycles are pretty much impossible to simulate, only thing to do is get out there and try it... The last ones demise was what persuaded me into getting a workshop tool, rather than a hobby too, though it was about four times the price.
  5. stoff3r
    stoff3r What's a Dremel?
    20 Nov 2006
    Without a spare battery, powertools are pretty much useless. If you have more than 15 mins of work to be done on some case, you will find yourself out of power, and no way to use it for another hour or so. Better get the 3000 if you are serious about doing some work :)
Tags: Add Tags
