Modding Dremel Bits?
Discussion in 'Modding' started by sickskater6911, 5 Nov 2003.
  1. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    Can someone explain to me or gimme a link that explains which dremel bits do wat and are for wat jobs.
    ty
    IF U FEEL THE NEED TO FLAME
    DONT
  2. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    i'd like to know as well :lol:
    all i know atm is that theres some roundy bits that cut, and circly bits that sand. :idea:
  3. Grump
    Grump The Mad Modder
    30 Mar 2002
  4. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
  5. Grump
    30 Mar 2002
    Ummm, isn't that what I said? :dremel:
  6. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Or you could go take a look at www.dremel.com :lol: Just messin' with ya Grump.
    The dremel site has a little form you can fill out that will show you what bits can do what you are looking for. It can be found here.
    "I need a bit/accessory for shaping -aluminum"
    Hit search and it will list all of the bits that do that. Then you can look through them and see what strikes your fancy. Maybe you like cutoff wheel type bits. Perhaps you prefer router type bits. Just check them out. It will even tell you how fast you should run your dremel with that bit and give you some tips for what you should or shouldn't do with it. :dremel:
  7. Grump
    30 Mar 2002
    I knew I shoulda stayed in bed longer. :grr:
