Modding Dremel Circle Cutter Question
Discussion in 'Modding' started by BigBig5, 30 Aug 2011.
  1. BigBig5
    BigBig5 Single Braid Sleeving
    28 Apr 2010
    Can a Dremel Circle Cutter cut metal like steel and aluminum?:confused:
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    With a dremel, yes
    by itself, no
  3. BigBig5
    28 Apr 2010
    So will the bit work?
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    It should, but be prepared to have spares. A series of shallow cuts (instead of one deep cut) and coolant may be a good idea as well.
  5. The_Beast
    21 Apr 2007
    What bit are you talking about? you're very vague
  6. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    As The_Beast says, you'll need to be a bit more specific. Typically, Dremel will indicate the materials for which a given bit is designed. Find your desired bit here, and see if steel and/or aluminum are listed.
  7. Stuey
    20 Jan 2005
    I assumed he's talking about the multi-purpose cutter that comes with either the circle-cutter or straight-cutting attachments. It's a 1/8" thick spiral-saw-type of bit. I didn't think anything else could be used with the circle-cutter.
