Modding Dremel cutting disks supply.
Discussion in 'Modding' started by Kronos, 9 Mar 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Anyone got a link to cutting disks that do not break when you show them a bit of metal. My too is actually a Draper but same idea.
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
    Surprised at the amount of views yet no suggestions. Bought some from the bay as I have three screws that I need to slot asap.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Have you tried the reinforced ones?
    Reinforced discs
    I've had the general use ones shatter and go off like bullets, not had one of these do the same yet.
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers guys.
  6. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    The reinforced do shatter at times but it's rare. At my mother's house there are small shards of the non reinforced wedged forever into her dining room wall :D
  7. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    The reinforced quicklock disks are amazing but more expensive than the normal disks by some margin.
  8. AlienwareAndy
    7 Dec 2009
    BTW Glenn.. If you're cutting acrylic buy these.
    http://www.amazon.co.uk/Silverline-...94443751&sr=8-1&keywords=diamond+cutting+disc
    For the simple reason that they pretty much last forever. I bought a pack over a year ago and I still haven't changed out the first one I fitted lmao.
    They're about 1/3 as thick as a reinforced and are metal based. They go through acrylic like a hot knife through butter mate, an essential for the PC modder.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Bought some ordinary reinforced and a few quicklock to try.
    And it is metal Andy but will keep those in my Amazon wish list for future reference. Thanks.
