Modding dremel replacement? Quick answer if possible.
Discussion in 'Modding' started by herbs, 25 Jul 2003.
  1. herbs
    herbs Nobody but us chickens
    7 May 2001
    Where is the cheapest store (not online) to get a dremel or clone? i.e the B&D rotory tool as my one went tits up. I had a quick look at B&Q and the rotory is £39.99
    Many thanks.
    Sorry mods I meant to post this in Modding so if you could do the honours and move it to there
  2. KniFenForK
    KniFenForK Minimodder
    11 Oct 2002
    B&Q do a PowerPro version of the dremel, 14.99 with a cool box and 40 additional pieces - bargain! Esp as its fairly good quality amd takes dremel parts!
  3. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    thats the one ive got ;) Get some proper dremel mandrels tho, i broke the supplied one on the day i got it :hehe:
  4. wharrad
    wharrad Minimodder
    26 Jul 2003
    Dremel
    I bought one from Focus Do It All for like £19 with lots of spare cutting discs and that in a box set.
    I've had a real dremel before and it's as if Dremel built it for Focus, just painted it blue! But I go with the idea of buying dremel parts - the focus ones just snap.
    Chewie (wharrad)
  5. herbs
    7 May 2001
    I couldn't see the £14.99 one, but I got the £29.99 one it has a stand and that cable bit also has 150 pieces. I was in a hurry as the ali case was in a sorry state, and needed sorting. Anyway it's alot better than my B&D wizard which gave up the ghost, I couldn't even open up the tool as it had some funny screws they look like hexs but they aren't.
