Modding Dremel Workstation 220 Review
Discussion in 'Article Discussion' started by brumgrunt, 29 Feb 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. mute1
    mute1 What's a Dremel?
    16 Sep 2009
    Glad to see you guys continue with reviews of stuff like this. Thanks and keep it up. :)
  3. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I could build a house with one of these, is there anything they can't do?
  4. David
    7 Apr 2009
    Does this stand accommodate all Dremel rotary models? Mine is getting on a bit, but I wouldn't get a stand if it meant replacing my Dremel with a newer model.
    Oh, and someone sack the proof reader [/pedantry] ;)
    Carrie likes this.
  5. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    Yeah, same with me. however, my model has the 'collar' too, and it fits the extension piece, so I don't really expect trouble there
  6. €gr€s
    €gr€s What's a Dremel?
    2 Sep 2006
    On the other hand, do NOT even think about buying this plastic piece of **** if you do really precise work. It may look bulky enough to hold the drill in position, but that is not true. If you grab the drill bit and push on it, it will move +-1mm. Carbide drill bits with diameter less than 0.8mm wont last a second, small movement and they will snap. It is useless for PCB drilling.
    If you want quality, metal is the only choice. After few days I bought Proxxon MB 140/S and i can successfully drill 0.1mm holes with carbide drill bits. http://www.proxxon.com/eng/html/28606.php
  7. Lance
    Lance Ender of discussions.
    6 May 2010
    How much did you pay for that though?
  8. Combatus
    16 Feb 2009
    I didn't have any problems to be honest and you can see from the images that it's more than capable of coping with modest tasks, which is all you can expect given the price - you could drill holes for 24-pin ATX conector cables no problem. It only costs £30 though so if you're expecting it to be as solid as a £100 drill press, well...
  9. weesteev
    weesteev What's a Dremel?
    19 Dec 2011
    Great review Anthony! Do you know if the cordless Dremel would fit this stand?
  10. €gr€s
    2 Sep 2006
    Well, for Dremel Workstation 220 I paid 49€.
    Proxxon MB 140/S a week later was 47€.
    You can't use Dremel tool in Proxxon stand though, so you can add 32€ for Proxxon drill.
    Dremel stand is more than capable of coping with modest tasks, no argument there. If you already have dremel tool, it is good choice. But if someone is looking for a really good drill stand + tool combo, he should really go for Proxxon.
  11. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    essentially its a fancy clamp?
  12. pendragon
    pendragon I pickle they
    14 May 2004
    I have one of these... fits my Dremel XPS 400 without too much trouble.. my only gripe is the bolt that secures the main metal pipe doesn't always stay tight when moving the workstation from place to place.. but, I certainly recommend it .. it's AWESOME for use a drill press .. saves lots of headache trying to drill straight holes into rounded pipe!
  13. Combatus
    16 Feb 2009
    Yep should do. The big plastic collar at the front of your Dremel should remove to reveal a large thread - it's that which screws into the clamp on the workstation.It's the same thread that's used for all their add-ons, such as the Flexible shaft.
Tags: Add Tags
