Storage Drive Swap between main rig and server
Discussion in 'Hardware' started by Mechh69, 4 Aug 2012.
  1. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Ok here is the situation
    My main rig has 2 80 GB disc in Raid 0 I want to clone the disc and put it on a 500 GB hdd, then swap them out to my server where i have a disc failed.
    I have my server set up with the OS in Raid 1 the 2 drives are 250GB. Can I clone the good drive and put in on an 80GB drive and set 2 of them up in a Raid 1? I don't have the money to buy another 250 GB drive at the moment and there is not 250 GB of data on the raid it is only for the server OS.
    So is it possible? Suggestions/comments please.
  2. Mechh69
    16 Sep 2009
    No comments? Sorry for the bump
  3. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Yes, that should work. You're talking about doing it step by step which is good as it will allow you to test each step as you go (so get the server running on a single drive as a test and then raid it).
    But...
    Do you have backups of all your key data? If not then sort that out.
  4. Mechh69
    16 Sep 2009
    The server is my back up for all my computers. I just noticed that the Raid was degraded and would rather change out the disc than have both disc fail. I do not store any data on the OS drive on my server I keep it in a Raid 1 so that I do not have to spend countless hours setting everything up again.
    It shouldn't muck things up going from a Raid 0 to just a single disc should it? FYI it is a hardware raid not a software raid.
