Windows Driver cleaner
Discussion in 'Software' started by ModSquid, 28 Nov 2018.
  1. ModSquid
    ModSquid Modder
    16 Apr 2011
    Afternoon all!
    Very quick query this time (makes a change for me) - can anyone recommend a decent (free, if possible) program for removing old unused drivers from the system?
    I'm thinking mainly about getting rid of the leftovers following hardware changes, for example.
    Thanks in advance!
  2. adam_bagpuss
    24 Apr 2009
    cc cleaner ?
  3. ModSquid
    ModSquid Modder
    16 Apr 2011
    I don't think it does drivers though. At least not from what I could tell.
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
  5. Broadwater06
    Broadwater06 Minimodder
    10 Apr 2016
    Such tools ideally be used if you have problems uninstalling/installing drivers so if you successfully installed drivers for hardware changes and doesn't impact then you don't need to run these tools.
  6. ModSquid
    ModSquid Modder
    16 Apr 2011
    Oh - did not know that...
    Do the older drivers not just then sit clogging up the system?
  7. Sentinel-R1
    13 Oct 2010
    Most driver components are removed by the uninstaller. There can be remnants left behind though, hence why these tools exist.
  8. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    These days for the most part you can just trust the uninstaller, unless you've got an actual problem you are observing.
  9. yupson
    yupson What's a Dremel?
    31 Jan 2018
    CC cleaner is really efficient
