I have a slight problem which seems to be changing each time I try and fix it the error started out as opengl32.dll not found. exit is the only option so I downloaded opengl32.dll then the error changed to driver components mis-match so I downloaded what I believe are the correct and most up to date drivers for my graphics card. my card is NVIDIA GeForce4 MX 440 with AGP8X The driver I downloaded was 71.84_win2kxp_english.exe from Nvidia's web site now the error I get is this one error msg does anyone know how to fix it as its effecting at a minmum the programs listed below Paintshop Pro 9 Sonic Stage Warcraft III and these are the ones I know about what else Its effecting I have no Idea
What OS are you running? I found some information here and here, but it applies to Windows 2000 and 98, respectively. The second link contains some information about registering the DLL after downloading it, which may be of help to you. Good luck.
