Linux Drivers for dell
Discussion in 'Software' started by murraynt, 15 Jun 2010.
  1. murraynt
    murraynt Modder
    6 Jun 2009
    So i have decided to install abuantu mobile on my dell laptop due to it being very low powered.Will i run into problem for downloading drivers for the graphics and wireless cards?
  2. bulldogjeff
    2 Mar 2010
    You might find the graphics drivers are not available , in which case you'll be stuck with max resolution of 800x600 . Support for wireless drivers is very good.
  3. murraynt
    murraynt Modder
    6 Jun 2009
    everything seem to be perfect
  4. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    It should be fine, I've put Linux Mint (based on Ubuntu) on a couple of Dell laptops and everything worked fine, even the nVidia discrete graphics!
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Everything was fine except for the wi-fi but i think that is broke and not drivers
  6. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    GPU drivers are pretty good on Ubuntu these days. They're usually 6 months behind on the cutting edge cards, but older ones are invariably supported out of the box. It'll put an icon up in the top right corner if there is a binary driver available, but unless your gaming, the included driver should be fine.
  7. murraynt
    murraynt Modder
    6 Jun 2009
    i have to buy a wireless card for the laptop since the current one is broke,will there be drivers for this?
  8. bulldogjeff
    2 Mar 2010
    Theres good support for all the major brands, both internal and external.
