Hiya We bought a DS Lite for my bro for Xmas, so I opened it a few weeks back to check it out, all was fine, but as I bought the M3, I put some stuff on it and got the DS Lite out again, but after I noticed the screen could be pushed down a litte, so it seemed lose, I wasn't bothered with it as who is going to push the screen down, but when I turned it off, it looked like the screen was wet, but actually the inside of the screen seems like it's leaking or something like that, when you apply little pressure on it it goes away, let go and it comes back. But when the DS is on you don't see anything at all, only when it's off. It's been boxed up for a few days, should I see if it's the same, and if so should I return it to the shop? Will they give me a replacement there and then? Cheers
it's certainly not 'leaking' anything. It must only be an air bubble between two protective layers.. You could still return it though
