Apple .DS_Store
Discussion in 'Software' started by keef247, 28 Jan 2009.
  1. keef247
    keef247 Minimodder
    11 Aug 2006
    basically i think i unchecked a hide hidden files/system files whatever it was option in finder or somewhere on 10.5.6 OS X and now i'm getting these bloody annoying .DS_Store files on my desktop and in every folder.
    simply put how do i get rid of them/hide them.
    really annoying me now!
    cheers
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    In Terminal
    defaults write com.Apple.Finder AppleShowAllFiles NO
    Will probably need to reboot afterwards, or just relaunch Finder.
  3. Firehed
    15 Feb 2004
    Just in case you're curious, they're basically the Mac equivalent of thumbs.db; I believe they're the Spotlight index contents for any given folder. So hiding them (as above) is a whole heck of a lot more practical than getting rid of them entirely.
  4. keef247
    keef247 Minimodder
    11 Aug 2006
    ok cheers
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    just wait til you discover that it also litters every folder you browse to on all your network drives with them...
    there's a command to disable creation of .DS_STORE files on all network media though:
    defaults write com.apple.desktopservices DSDontWriteNetworkStores true
    terminal again. i recommend you do that :)
  6. bradford010
    7 Dec 2001
    Spotlight index data is stored in the .Spotlight-V100 directory at the root of a volume (again, the preceding dot indicates it's hidden).
    .DS_Store is just related to the folder it's in, containing things like icon layout, window position, background image and such like.
  7. keef247
    keef247 Minimodder
    11 Aug 2006
    nope didn't work
