DSL connection :(
Discussion in 'Hardware' started by sKaD, 22 Nov 2007.
  1. sKaD
    sKaD What's a Dremel?
    21 Nov 2007
    I had to settle for DSL when I moved back to TN and well, it's.. slow. The highest download rate I get per file is probably 100kb/s and with multiple files I probably get a total of 150kb/s :( it's 3mb/s down and 512kb/s up.
    Is that what I should be getting? What's a good bandwidth test site (for US)?
    Thanks..
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
  3. Hardware150
    Hardware150 Minimodder
    8 Jul 2006
    I get 220k/s on 2mb.....
  4. sKaD
    21 Nov 2007
    I'll run the speed test as soon as two of these videos complete.
    So what could be causing my downloads to be slower?
  5. Krikkit
    21 Jan 2003
    Could be a million things - what router are you using? What speed does it claim you're connected at?
  6. sKaD
    21 Nov 2007
    I'm not running through a router, I'm connected directly to the DSL Modem using the Ethernet cable.
  7. sKaD
    21 Nov 2007
    I assume with a 3mb connection with DSL I should be getting higher than 1500~kb/s on a bandwidth test.
  8. sKaD
    21 Nov 2007
    So I called Bellsouth and complained, she had me run one of their speed tests and well..
    She set up an appointment for a tech to come tomorrow morning so :)
  9. JCG
    JCG What's a Dremel?
    1 Dec 2005
    Maybe to distance between the distrution point and you home is to large. That's killing my speed.
  10. sKaD
    21 Nov 2007
    I hope that's not what my problem is :( however, I do live on the outskirts of town =/
  11. sKaD
    21 Nov 2007
    Finally! It's been fixed. I'm now getting 300kb/s downloads and
  12. lworbey
    lworbey What's a Dremel?
    23 Nov 2007
    Just out of curiosity, do you know what they did to fix it? :confused:
  13. sKaD
    21 Nov 2007
    Well, a tech came down and tested his pocket DSL router to determine the lines were just fine, then he swapped my DSL modem for another one that didn't work, so he then swapped it for a DSL Router and still the same issue. So he went back to the server location and then came back then left again and said it was a problem with their servers that a tech that fixes that will call me. That tech called me and said it was a problem with .NET who provides the internet to AT&T and their provisioning with my account and they should call me on Monday (2 days later) and Tuesday the internet was working, but no phone call.
    So no idea =/
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Sounds like they b0rked setting your line up, and told their hardware at the 'phone exchange to give you a lower speed than the line was capable of.
  15. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    In the uk the channel 5 program The Gadget show is doing a survay and starting a movement to sort out this BS trading by suppliers.
