Windows Dual Boot XP
Discussion in 'Software' started by Headspark, 21 Jan 2007.
  1. Headspark
    Headspark Minimodder
    23 Feb 2005
    Hi all,
    I want to know if/how i can format the empty space on my HDD, atm its all used for this XP install, is there i way i can unformat empty space, and use it to install 64bit xp on??
    any 3rd party software i can use? can i do it!?
  2. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Yeah you can - Partition Magic.
    But it's not free ;)
  3. Headspark
    23 Feb 2005
    would that allow me to partition in windows, then boot of the 64bit cd and install to that partition?
  4. Headspark
    23 Feb 2005
    Anything free around?
  5. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Knoppix LiveCD has 'qtparted' I believe is the program that can unformat spaces and shrink your current NFTS partition to make some space for 64bit
  6. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Ask yourself how much trouble XP 64 is actually worth. If you'd also like the space for Vista or Linux or something else that will work, that's one thing. But my understanding is that XP 64 was a horrible sin just shy of Millennium.
  7. Headspark
    23 Feb 2005
    XP 64 is working fine for me atm!.. appart from one driver i cant find ;)
  8. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Yup... Partition Logic...
  9. hardeez1
    hardeez1 What's a Dremel?
    8 Sep 2006
    I really like Acronis Partition Expert .. better than Partition Magic, try to get that somewhere.
