Windows Dual Booting
Discussion in 'Software' started by ajack, 13 Jul 2003.
  1. ajack
    ajack rox
    17 Apr 2003
    Hi i am looking to dual boot my shuttle. Its already got redhat installed on an 80gig drive. I want to install windows 2k on a separate hard disk (just a really small one) Can anyone give me any pointers? All i have found is how to install linux on top of XP etc. How can i choose which hard disk to boot?
    Any help appreciated
    Thanks
    JW
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Which hard drive to boot from can be selected in the BIOS.
  3. ajack
    ajack rox
    17 Apr 2003
    But that means i have to change the bios each time? Is there not another way to choose which boots?
  4. cellis4766
    cellis4766 What's a Dremel?
    10 May 2003
    Although I have never used it, I have been told that Partition Magic makes this easy!!!
    I have this friend, who knows someone (just kidding...) who set up a dual boot almost exactly as you describe.
  5. Hargle
    Hargle What's a Dremel?
    13 Oct 2001
    I recommend using LILO. You just write a few lines in the lilo configuration file telling it what boot options you want and then select from a menu what you want to boot each time the system boots. Just search on google or look for the LILO HOWTO on tldp.org.
  6. fathazza
    fathazza Freed on Probation
    20 May 2002
    u should be able to installwin 2k or what ever, and then itll come up as an option during startup.
    Or at least thats what happened when i installed xp with mandrake on a dual boot.
    defo make sure its either on a different partition or a different drive tho.
  7. pranks7er
    pranks7er mange tout
    25 Dec 2002
  8. loply
    loply What's a Dremel?
    26 Dec 2002
    Rather than lilo Id suggest grub - it achieves the same but is much more flexible, and a godsend in emergencies thanks to the ability to change its config without an OS.
