dual cpu system
Discussion in 'Hardware' started by Elspuddy, 14 Dec 2001.
  1. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    o.k this is my next system for next year , and i'm think i'l go dual this time , but dual what, amd or intel,
    what main boards are out for for both makes of cpu, thay dont have to have the raid options, and i want to go chep as pos on the main abords
  2. SonicSilicon
    SonicSilicon What's a Dremel?
    4 Nov 2001
    Well the answer is . . . a question (don't you just hate that?!)
    Anyway...
    Which OS are you planning on running on said dual-processor system?
  3. Phil
    Phil What's a Dremel?
    19 Jul 2001
    is that counter question related to drivers ?
    is linux support for the AMD dual boards not that good ?
    what about win2k ?
  4. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    i;l be running win 2k , i'm not that into linux ;)
  5. relix
    relix Minimodder
    14 Nov 2001
    wait until MSI releases their dual AMD, and then buy that one
  6. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    You can get pretty cheap motherboards for dual Intel CPUs but the AMD ones are still quite expensive at the moment. Especially as the only decent option seems to be the Tyan board!
  7. Kevin
    Kevin What's a Dremel?
    6 Jun 2001
    if u wan a quiet and cool dual CPU system, go for intel
    if u want raw power with no concern over noise as much, AMD's the way to go
    i can't afford 2 Swiftech MCX-462s aniwae :D
  8. Kevin
    6 Jun 2001
    check out EPoX's picture of the M762
    sweet dual CPU mobo
  9. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    got a url for that mainbord ?
  10. Phil
    19 Jul 2001
    There's nothing about it anywhere yet it's so new....
    all I could find was this : http://hardware.no/nyheter/oktober01/epox.html
    which has no pics, but tells you this :
    4GB DDR SDRAM i 4 DIMM slots (PC1600/PC2100)
    1 AGP 4x slot
    2x64bits PCI slots - 66MHz
    2x32bits PCI slots - 33MHz
    ATA 100 kontroller
    4USB
    Intel 82559 LAN kontroller
  11. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    o.k thats amd, what about intel ?
  12. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
  13. beav
    beav What's a Dremel?
    18 Dec 2001
    My 1.266 Tualatins oc'd to 1.5 equate plenty of power. The new p3's come extremely close to AMD on performance, if not better on some applications. The only problem is the price, as those processors go for around 250 dollars.
    I use the iWIll DVD266u-RN motherboard, which is a fine board based on the VIA pro266t chipset. The ddr isn't needed and doesn't offer any imporvement of sdr, but i had some extra ddr ram, so no biggie. Tyan makes some great dual tualatin boards, along with supermicro's serverworks motherboards.
    As for AMD dualness...Tyan Thunder K7 is at the top of my list. The new MPX boards will probably have the overclocking features etc, but you can't beat dual 3com serverclass NIC's, the rock solid stability and integrated scsi.
