Lo guys, Anyone out there running a SINGLE Nvidia card with dual monitors attached who would like to share their xfree86 config? thanks in advance
I did this awhile ago but didn't have the deskspace for two 19" crt monitors... i did save my config though anyways... my card has a vga port and a dvi port... i got a dvi-vga converter for pretty cheap this is all that I changed Code: Section "Device" Identifier "nvidia" Driver "nvidia" Option "TwinView" Option "SecondMonitorHorizSync" "30-86" Option "SecondMonitorVertRefresh" "50-160" Option "TwinViewOrientation" "RightOf" Option "MetaModes" "1600x1200,1600x1200" Option "ConnectedMonitor" "crt,crt" End Section Be sure to change everything to suit you
I have no experience of dual monitors, but isn't this kind of thing what the Xinerama package is for? Sam
see http://www.kiwiuk.net for an alternative way to setup dual screens with NVIDIA graphics. Its under Linuxguides. I've found twinview to be better because I can run OpenGL on both screens but the native X method (as on kiwiuk.net) is better for games. I've not had any sucess with WINE at all with dualies setup - Hl2 crashes in native X dual monitors and starts overlapping a non-existant screen in Twinview mode. Xinerama is an extension that tells window managers things about which parts of the desktop are on different screens. This helps with things like keeping popup dialogues on one screen (not half on each) and having seperate panels on each screen. If you use Twinview make sure the "Option "Xinerama" option in X is OFF because the NVIDIA driver provides its own Xinerama data when twinview is on. Hope that helps, Jon
Ahh, ok. I really should invest in a second monitor- sadly my bank manager won't allow it! Cheers Sam
Twinview is good pbut I find it a pain for playing games because you have to switch modes manually first. Anyhoo, here's my work PC's xorg.conf for my Quadro 100 under FC3. Code: # XFree86 4 configuration created by pyxf86config Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # RgbPath is the location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # Multiple FontPath entries are allowed (they are concatenated together) # By default, Red Hat 6.0 and later now use a font server independent of # the X server to render fonts. RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "gb" Option "XkbOptions" "ctrl:nocaps" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "SyncMaster" DisplaySize 340 270 HorizSync 30.0 - 81.0 VertRefresh 56.0 - 75.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" VendorName "Videocard vendor" BoardName "NVIDIA Quadro 4 (generic)" Option "NvAGP" "3" Option "NoDDC" "true" Option "CursorShadow" "on" Option "NoLogo" "false" #Option "DigitalVibrance" "3" Option "TwinView" "true" Option "TwinViewOrientation" "LeftOf" Option "SecondMonitorHorizSync" "31-81" Option "SecondMonitorVertRefresh" "56-75" Option "MetaModes" "1280x1024,1280x1024; NULL,1280x1024; 1024x768,1024x768; NULL,1024x768; 800x600,800x600; NULL,800x600; 640x480,640x480; NULL,640x480" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 Modes "1280x1024" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection
