Case Mod - In Progress Dual Loop Phase Cooled Lian Li By RetroGamer1990 - **UPDATE 04/02/2010 Video**
Discussion in 'Project Logs' started by retrogamer1990, 22 Mar 2009.
  1. bagman
    bagman Well-Known Member
    18 Apr 2009
    you are going to have to have a reason to put up that comment :nono::miffed:
    any way liking the hardware espaccially the waterblock
  2. b1g-d0g
    b1g-d0g Well-Known Member
    30 Sep 2001
    Can link to the problem on another forum if you need proof pm me.
  3. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    right can you please STFU about this, I've sent a replacement 4870x2 waterblock to capriboy FOR FREE to cover the one that got lost in the post, okay? I didnt have to do that, but I didnt want this to get out of hand. so dont put comments like that in my build log thread! its neither relevant or true!
  4. b1g-d0g
    30 Sep 2001
    Get on chilled and sort it out then one guys going to come visit you soon.
  5. andrew8200m
    andrew8200m Well-Known Member
    4 May 2009
    Retro, I think it's only fair you send te parts to people over at chilledpc, I know mrbristal finally got his mobo but what about the others with the 4870x2 and the water blocks??
    Andy
  6. Azza
    Azza Cam Mitchell
    1 Jul 2007
    Thankfully everything has been sorted before I had to ring his parents.
    For anyone thinking of buying anything off this guy please don't. :)
  7. retrogamer1990
    12 Jan 2009
    okay, update! :D
    My lovely hose fittings came today so i set about installing everything :)
    Pics :)
    Nearly there, just gotta install the pumps and fill it all up, then i'l be 95% complete with minor things left to do :)
  8. retrogamer1990
    12 Jan 2009
    okay guys, help needed from you creative types :D
    so, the right hand side bays need something to cover them since i can no longer put the standard bezels in there.
    I decided that what would work was a 2mm peice of alu/steel the height of 8 bays and the standard width. I could then attach this to the front fascia, thus solving the problem and prettymuch completing the pc.
    you can see the problem here (apologies for the poor quality photo, it was done in a hurry)
    so, what i need your help for, is I can't decide what I want there. Should I just get it done in one plain white cover? Or would it look better in black? should I even get a design/ text lasercut into it? any designs or opinions you guys have would be massively appreciated :)
    heres what you have to play with to get the idea (its probably the worst photoshop job i've ever done :p )
    thanks!
    Nick
  9. retrogamer1990
    12 Jan 2009
    oh yeah, i forgot the lighting pr0n :p
    case, side on, light on, internal lights off
    case side off, lights on, internal lights off
    side off, lights on, internal lights on,
    darkness, internal lights on ;)
    and a little bit of extra sexyness
  10. el2k
    el2k Well-Known Member
    18 Jan 2010
    She looks awesome mate, I for one love it.
  11. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Impressive !:jawdrop:
    Are you using watercooling and phase change?
    or just phase change?
    Could get it from the photos please explain me how your system is going to be cooled !:thumb::rock:
  12. retrogamer1990
    12 Jan 2009
    thanks guys :thumb:
    @raiden, The phase cools the CPU, and the motherboard and GPU have a watercooling loop each, theres a 120.1 cooling the motherboard and a 120.2 cooling the GPU :)
  13. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    How do you avoid condensation with this bad boy then?
    Must be honest I'd love to have a go with one myself!
  14. retrogamer1990
    12 Jan 2009
    first, I coated the socket area with vaseline, then the back of the socket, and also you put vaseline directly into the motherboard cpu socket. This helps to stop condensation when running 24/7 sub-zero cooling.
    I then applied a layer of artists eraser putty around the CPU and socket, forming an airtight seal around the components.
    Then On top, for extra protection / neatness I put a layer of black neoprene :) also there is a neoprene gasket between the backplate and motherboard. :)
  15. retrogamer1990
    12 Jan 2009
    Update :) 99.9% complete, just need a little bit of smoked acrylic for the front!
    WC Loops filled with no leaks first time! :D *chuffed*
    I also added two cathodes in the front, anyways here are the *almost* final pics :)
    the money shot....
    and the benefits of said temperatures?
    Aiming for 5ghz :)
    that's all for now folks! I'll post a couple more pics in the daytime & when I add the front panel, but it's as good as done :) - only took me a year! hehe
  16. el2k
    18 Jan 2010
    Is it wise to use the two ram slots closest to the phase cooler? Condensation and all.... or does your motherboard require you fill those two slots first?
    However, Been following for some time man and i have to admit it is a very very good quality build - very impressed.
    Always wondered why you went AMD though......
  17. imersa
    imersa Parvum Princess
    9 Apr 2009
    AMD!! That's like an LN2 pot on a 486! :D
    ahhaha.
    Phase cooler looks sweet! I've become very fond of mine!
  18. retrogamer1990
    12 Jan 2009
    yeah I did some digging online and it is alright if you've insulated well enough :) I've had no problems so far
    Its much cheaper, the white waterblock availible for the board matched the build, and the amd chips like cold temps more than intel :)
    thankyou!!!:thumb:
  19. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    in the words of a famous character from South Park, Holy sh*t dude! absolutely epic man. clean, simple. love it!
  20. retrogamer1990
    12 Jan 2009
