Dual monitors problems
Discussion in 'Tech Support' started by SJH, 18 Oct 2007.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    I'm having a couple of technical issues with my dual screens. I have a TFT plugged into my laptop's VGA port which I use as a secondary monitor but over the past couple of days it's decided that only the TFT can act as the primary monitor. Every time I try to set the laptop screen as the primary monitor it just disables the laptop's screen altogether.
    Also, the monitor's locations relative to one another keep changing (i.e. swapping sides), so I have to go to display properties and change the locations back to my preferences every time I turn the computer on.
    Can anyone help here please?
    Sam
  2. shadow12
    shadow12 I lie
    30 Sep 2007
    Do you have ati catalyst installed? If so check there it has a nasty habit of overriding settings.
  3. shadow12
    shadow12 I lie
    30 Sep 2007
    In fact I cant set my extra display to be primary it is always my laptops tft.
  4. SJH
    SJH Minimodder
    24 Dec 2003
    I'm not using ATI graphics, it's an Intel chipset :) Sorry should have mentioned this before.
    Sam
  5. shadow12
    shadow12 I lie
    30 Sep 2007
    Sorry man have not got a clue at this time.
  6. SJH
    SJH Minimodder
    24 Dec 2003
    OK but thanks for taking the time to try to help :)
    Sam
  7. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    right clock on desktop>properties>settings>advanced then go to the displays tab. I have spent ages trying to get some screens to work, only to find I have to double click on them there. (this is on my kaptop with a 9700)
  8. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Have you tried reinstalling the drivers and stuff like that? A long shot, but it might help...
  9. Firehed
    15 Feb 2004
    I had a similar thing at work. There's the normal advanced display properties section, which I guess is where you're working from. There's a special Intel one somewhere (I think it's in the right-click desktop menu somewhere, though I'm sure you can get at it in several ways) where if you set the settings from there, it seems to happily keep them.
  10. SJH
    SJH Minimodder
    24 Dec 2003
    Ah yes, found it, and it works perfectly. Thanks a lot :)
    Sam
