Displays Dual montior set up
Discussion in 'Tech Support' started by thelaw, 16 Aug 2011.
  1. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Afternoon,
    This is the first time i have tried to work with two monitors so i am a noob in this regard.
    My benq 21.5" arrived last night which i have now set up as my main display at 1920x1080.
    Decided that i would use my Acer AL1715B 17" 1280x1024 as a side display mostly for monitoring temps etc when gaming which works fine the game loads onto my benq leaving windows on the acer.
    The question is there any way to set up each display under there own desktop profile, the benq has has the wallpaper filled nicely and its moved the icons to the right onto the acer, which suits me however the issue is that the acer also has a copy of the wallpaper but expanded/exploded view and does not fit very well.
    Obviously however i adjust the wall paper on the benq just replicates over onto the acer meaning if i want it to fill or fit the screen on the benq it explodes it on the acer, in a ideal situation i would like to tell/have windows adjust the wallpaper on the acer to a smaller size than on the benq but that might be asking too much?
    Can i have a separate desktop background or even a different photo all together on the acer from the one on benq, Windows 7 is meant to be all user friendly, singing/dancing and all that so i am unsure why or to how to set up a separate profile for the acer, assuming it can be done?
  2. Edwards
    Edwards Minimodder
    8 Oct 2010
    thelaw likes this.
  3. thelaw
    10 Sep 2010
    ahh + rep
  4. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    +1 for DisplayFusion, fantastic app. I'm a registered user loved it so much and wanted to extra features, totally worth it.
  5. GaryP
    GaryP RIP Tel
    31 Aug 2009
    +1 for Display Fusion too. Registered version very controllable but the free version will do what you want.
  6. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    :D Thanks !
