Scratch Build – In Progress Dual Screen problem
Discussion in 'Project Logs' started by gamgam1986, 26 Apr 2009.
  1. gamgam1986
    gamgam1986 What's a Dremel?
    25 Apr 2009
    Hello everyone, i am new to online forums so help is always accepted. i have a question for anyone who can help. i have a dual screen system running off one gpu. i wanted to be able to play a game whilst having firefox open on th other. when i start cod4 or any game the second screen's resolution gets messed up. i can keep them open on seperate screens. has anyone had this problem or know how i can fix it? any help will be greatful. thx everyone
  2. Guest-23315
    Guest-23315 Guest
    ^^ Wrong forum...
    And try changing the resolution of COD4???
  3. Jenny_Y8S
    Jenny_Y8S Guest
    What a dull project log ;)
    I find some games just do this.
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    this belongs in tech support or hardware
    what are the resolutions/specs of the screens? Im using a laptop with 1680x1050 and my 2nd is 1024x768 and WMP11 and Firefox stay on the 2nd monitor. Are you using any 3rd party software for the monitor (IE, UltraMon)? When running games without UltraMon, it does what your describing on my computer.
  5. skybarge
    skybarge just chilling at work
    29 Feb 2008
    The way to fix this is to:
    - Cut the end of each screen, one on the left, one on the right
    - Fuse the two screens together
    - Then post up project logs of it
    Because you are posting in this forum, I guess you planning a scratch built monitor? good idea.
  6. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Make sure the game is running in proper resolution for that monitor, or make it in windowed mode.
  7. gamgam1986
    25 Apr 2009
    thanks for the warm welcome.......
