Dual widescreen wallpapers
Discussion in 'General' started by The_Gimpy, 8 Jan 2008.
  1. The_Gimpy
    The_Gimpy What's a Dremel?
    15 Jul 2004
    I just got a wicked deal on 2 new 22" samsung 226bw's and am in need of some new wallpapers. I've been using dual monitors for ages now, but my old library of wallpapers is pretty much useless as my previous monitors were not widescreen. Now I've tried deviantart and doing some quick google searches, but it seems most dual monitor setups or at least the wallpapers made for them, assume that both screens are 4:3.
    So does anyone know of some good resources for wallpapers that are going to work with my setup?
    Thanks
  2. Amon
    Amon inch-perfect
    1 Jun 2007
  3. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    DisplayFusion is pretty good for managing dual screen wallpapers. (if you don't use that already)
  4. Krikkit
    21 Jan 2003
    Deviant art is quite good iirc - I think you can search by size. Don't quote me on that though. :p
  5. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Look around on WikiMedia Commons, as well. There are quite a few high-resolution images there which would be well-suited to dual widescreens with just a bit of cropping.
  6. The_Gimpy
    15 Jul 2004
    thanks guys, I'll check out all those sites.
    Right now I use ultramon and the wallpaper manager in it, but I'll check into DisplayFusion, however, I don't really know if i will need anything more advanced.
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    check out featured panoramas and landscapes categories for some especially good wallpapers.
