Case Mod - In Progress DuallPhantoM REVERSED ATX!!!!!
Discussion in 'Project Logs' started by k.3nny, 2 Nov 2010.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow that orange tubing really pops! should look awesome Kenny :D
  2. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Teaser!
  3. Garf13
    Garf13 What's a Dremel?
    31 Mar 2011
    Haa, got to see that one up close and personal on FATlan ^_^
  4. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    UPdate :D!
    Old stuff dismanteling and draining and removing :)
    New reservoir spot, Let the work begin ;).
    Pump + reservoir connector.
    VGA powercable hole.
    Reservoir mounting, not needed, but did it for the safety.
    Detaillsssss ;)
    Pumpplacing.
    rejoining everything and placing the BP fittings etc.
    Masterclear hose 1/2 looks awesome!.
    Soon more, waiting for the EK Coolstream 360 radiator.
    Lots of thanks to :
  5. Guest-56605
    Guest-56605 Guest
    I'm liking that sooooooooooooooooo much :D :thumb:
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks budd!
  7. Saltire35
    Saltire35 Drunken Scotsman
    5 Dec 2010
    Friggin' awesome build !
  8. The boy 4rm oz
    10 Apr 2008
    I must say, very well done with the pump and res, so neat and tidy.
  9. Torin
    Torin What's a Dremel?
    8 May 2011
    Love the colour scheme and now tidy it looks so nice.
  10. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Fresh update ;)
    Template of the top.
    Cpu block leds:
    Cool
    Reservoir led.
    Vga cables and some routing.
  11. bagman
    bagman Minimodder
    18 Apr 2009
    I see what you are trying to do and i can't wait to see the final result
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking good & tidy k.3nny :thumb:.
  13. bulldogjeff
    2 Mar 2010
    This is turning in to one of those mods that just keep evolving until there's nothing let to do apart form pull it all apart and start again....Looks good though, I like your approach to the res...Nice one dude
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Teasert ^^
  15. MilOk
    MilOk What's a Dremel?
    18 Dec 2010
    3x120 or 3x 140 ?
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    3x120 ;)
  17. MilOk
    18 Dec 2010
    go foward :p
  18. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Paint of the 2x200mm to 3x120mm converter is drying in the sun ;)
  19. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    update :D
    360 rad came in today (13:00).
    al the parts for making a 360 top :p.
    after some cutting.
    perfect ;)
    Creating the 2x200 to 360 converter.
    Drilled some holes.
    Meanwhile i painted the top of the case.
    Converter is done.
    Also painted is flatblack:)
    Radiator reversed taping?
    Oww ;)
    Ah bummer :( the on/off console is blocking the 3rd fan :( need to fix that nexttime.
    Rad montage succesfull :clap:
    Front + top cover mounted, Look cool :lol:
    Last 2 hoses connected and "leaktesting ;)"
    no leaks? keep on going then :)
    Some early "nightshots"
    Many thanks to Freddy from Www.HighFlow.nl!
  20. MilOk
    18 Dec 2010
    beautyyy 5* =D
