Dualmaster
Discussion in 'Project Logs' started by coolmiester, 28 Jun 2005.
  1. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    btw , will the rad clear the first cd bay ? cant really see how high the rad is in the pic
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Oh my gosh... another WaveMaster by Coolmiester. :clap:
    What else to do than subscribe?
    Like those WaveMasters by the way. (owning a Soprano myself :D)
    Oh, and send me the Hardware you'll be fitting in there. Love to have the Dual + SLI board. :D
    :~subscribed.
  3. yatesy
    yatesy What's a Dremel?
    10 May 2005
    Quality project, can't wait to see the end result!
  4. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Cheers for the positive replies even though this is probably the third or forth time i've put you lot through this.
    Anyway.......quick update.
    I've already done a run through on how to mod a Laing DDC Pump to 1/2" but this one is a bit different so will add it to the log anyway :D
    The pictures speak for themselves really but i'll do a running commentary best i can between pics (and there's quite a lot of them so be warned)
    Started off by demmeling out the centre section
    but this time once the hole was drilled used a 9/16" UNF tap
    so the Danger Den Hi-Flow barb screwed in like so!
    Then filled it up with 2 part Araldite and left it to go hard..the glue that is :D
    I also cut the thread from another DD barb and glued that on the out-let as well
    Now for the fun part. Filled the top of the pump with 2 part body filler...
    ....just like icing a cake :D
    Then sanded it down with ruff sand paper and filled the low spots with more filler.
    Filled and sanded a couple of times then moved on to smother wet n dry paper till all the imperfections were gone
    Masked the barbs off
    then a couple of coats of primer followed by a light sand with 2000 grit wet n dry
    After the primer, gave it 5 coats of the closest metallic blue paint i could find that matched the rest of the case and also chopped the mounting lugs off the bottom bit of the pump and gave that a few coats of aluminium paint
    The colour is not an exact match but near as dammit
    And finally along side a standard Laing DDC
    Sorry for all the pics :duh:
  5. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    :eeek:
    Sweet pump work, Im sure it doesnt leak right? Keep it up! :rock:
  6. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    damn nice dude
  7. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Great mod on that pump. Like it's a real product, so clear. :rock:
  8. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Aww, that's a purdy pump. Love it. :)
  9. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Looking good with the pump, its a shame that you didn't fill the small gap that would have been below the inlet barb. It removes the smooth look, slightly.
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Looks better than the original!
  11. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    nice pump
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Excellent work :clap:
  13. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Dude... I'm subscribing. I hadn't thought body filler could be used for this. So...
    /writes down on a memo
  14. Jipa
    5 Feb 2004
    Modified pumps looks nice! I'll be watching this. What PSU will you use? two processors want lots of current..
  15. Firehed
    15 Feb 2004
    Nice job with it. You should sell that type of pump mod service (or do you?). VERY close color match - I can't tell a difference on the metallic paint.
  16. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Damn, thats so sleek! :)
    Nice job!
  17. frodo
    frodo What's a Dremel?
    1 Nov 2003
    i REALLY like that pump, it looks so damn smooth and clean, will work nicely in the case!
  18. perplekks45
    9 May 2004
    You ain't serious, are you? You just turned a crappy looking piece of plastic into something you wouldn't recognize...skills... nothing to add. :jawdrop:
  19. ShinySwede
    6 May 2005
    Your the man coolmiester=)
  20. coolmiester
    31 Dec 2002
    Cheers for the positive feedback and especially to whoever gave it the 5 *****'s :thumb:
    In all honesty i didn't have a clue how this would turn out but knew it had to look a little better than the standard DDC.
    The PSU that i chose was an Enermax ESP 660W ATX2.0 SLi which i hope should be enough and fits into the Wavemaster......just!
