Modding Dummy Keyboard Circuit
Discussion in 'Modding' started by Isotopian, 17 Jan 2006.
  1. Isotopian
    Isotopian What's a Dremel?
    19 Oct 2004
    Hey all, I have an interesting issue. A system I built for someone uses one of those awesome dual joystick arcade controllers. The issue at hand here is this controller does not work without a ps/2 keyboard connected (it passes through the signal).
    Here's my question. Without plugging in a keyboard, can I build a dummy circuit that will fool the computer into thinking a keyboard is attached? This may turn out to be easy, or way hard, I don't know.
    If need be I'm just going to pull the circuit board out of my spare keyboard, but I'd prefer not to if at all possible.
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    err, cant you just take the controller board out of a keyboard, and just use that, it would certianly make the computer think that a keyboard was plugged in..., thatd be my first suggestion without knowing more about what you need.
    cheers, Warrior_Rocker
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    If its in an arcade cabinit leave it connected
    But just remove the controller from a cheep keyboard and stick in a project box.
  4. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    yeah, go to your local tip, scavange a keyboard and use the control from that. or better still, put a keyboard into/onto your arcade machine incase of setup issus :)
  5. Warrior_Rocker
    26 Jun 2005
    isnt that kinda what i said, yay for bit-tech tripple posters of the same information :clap:
  6. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    Yay for people who don't read the post and then flame others for double/triple posting. :clap:
    Maybe if you read his post you would have noticed this:
  7. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    :lol: funny stuff
    Isotopian: What OS are you using?
    If it's Linux, then disabling the 'check for keyboard' feature in BIOS would be the first thing to check. After that, disabling APM seems like one solution. Found that on the first page of Google results.
    If it's Windows, I'm not sure I've heard of it working without a keyboard.
  8. customh
    customh conflagration.
    22 Oct 2005
    Id imagine you could take apart the keyboard, look of you need any resistance and get a ps2 to usb adaptor, dissect it and jump em all.
  9. AJB2K3
    12 Dec 2005
    Your better of with one tucked away.
    We were saying that thats probubly the best way to do it.
    But you realy should try GOOGLE because you then whould of found
    http://arcadecontrols.com/arcade.htm
    USE SEARCH AND GOOGLE BEFORE POSTING STUPID THREADS.
  10. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    Personally I put a wireless reciever in mine, purely for neatness and ease of setup, however mine uses a j-pac and passthrough isn't required just optional.
  11. customh
    22 Oct 2005
    AJB2K3, we are here to help people not down them-- right?
  12. Isotopian
    19 Oct 2004
    Perhaps I didn't make myself perfectly clear. The problem is not with the OS, it's the joystick itself that requires the keyboard. It's a Hasbro HotRod SE (in fact, that same one that is in the first link on the website you so thoughtfully recomended.
    The Hotrod has a built in keyboard kinda circuit which generates a keystroke for every button push. It simply doesn't work without a keyboard hooked up. I think I'm gonna bust out my trusty multimeter and see if I can figure out something. Otherwise, I'll just go with the keyboard circuit.
    And AJB2K3? Please use proper grammar and spell correctly before calling me stupid. Then I might think about it.
  13. theagent
    theagent What's a Dremel?
    4 Nov 2003
    some people just like to consider themselves better than others. i've never figured out what to do with them.
  14. AJB2K3
    12 Dec 2005
    Perhaps you should do researce first cus not everyone is able to easly pass the exam in ther native language!!!
    Yes but when that help is ruddly thrown back at you is realy get on peoples nerves. :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  15. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    ..Sorry for being a nosey parker...but I can understand what both parties are saying or suggesting ...BUT... I would rather trust the WISE BIT-TECH MODDERS suggestions/answers than Googles......The Boys...oops...and Girls over here are modder and in some weird but wonderfull way we are like brother & Suster of the modding world .......So please play nice....... :wallbash: :thumb: :nono:
  16. customh
    22 Oct 2005
    DELETE THIS
  17. customh
    22 Oct 2005
    We like to trust the answers we get here rather than research on google or w/e
    Sorry: double clicked reply on accident, bit tech is running really fast, so sorry for mirror post
  18. Isotopian
    19 Oct 2004
    And on that note... we're officially off topic and finished. Thanks to those who helped.
