TBH, more things are starting to work properly now. However some things require a little tweaking. In the shortcut's properties, under the compatibility tab: Run program in compatibility mode for Windows XP SP2 Disable desktop composition Disable display scaling Run this program as administrator Try that.
I did they have good working drive for the card but they don't have a DVB programe with that nilesat 101/102 EDIT : I did that it no hope still can't get that sat chs
No, the DVB software is not very compatible because of DX10 and DRM embedded in the system. ATi are shockingly bad they reccomend you pay for another piece of software.
lol no the ATi media center not working at all with my VIVO.... but I asked long time ago and no one answered me this is DVB-T now I have skystar 2 sat card it was work perfect in xp and in vista I have a driver but not the DVB software that's the problem this is DVB-S I want DVB-S Software with vista and DVB-T software with vista thanks very much
dudes forget it any ways thanks for all who tried with me I respect that too much however TechniSat Support dudes helped me and fixed the problem they Pros and replay me at the same time at any day time mean any time send email to them they replay me with the fix....... wooooooot now every thing is very damm well in vista all things.. all I have working with vista very damm WELL........ wooooooooot **** XP vista is the king now yayayay all things works every thing works well in vista now guys you keep say media center and it Support Tuner cards I have Sat car not Tuner any ways thanks for bit-tech members and for TechniSat Support dudes woooooooooooooot
okay I will put photos soon about how I fixed it but now I'm really busy for the holiday thing No problem I promies I will post the fix thanks very much guys
lol okay as you like here the steps IT's not genraly.. Only for Skystar 2 cards.. ( they rocks ) - download the software and vista driver from here ( diret link ) http://www.technisat.de/download/en/soft/441B20070306web.zip - Open DVBViewer TE -> Channel -> Channellist -> switch to layer "Channel Scan" - Enter Target Root (e.g. Nilesat) - select Satellite as Reception Type - From Transponder List select "Nilesat 101, 102" - Hit the "Scan Range" button and wait till the scanning process is finished - make sure that you have the all codecs for vista ( mpg2..etc ) the vid will not work with codec and enjoy watching porn rofl no problems this time I helped you guys not You
