what size are the screws that are used to mount the dvd drive? I mean the size of the holes on the drive? Is it a #4-40 screw? i know #6-32 won't fit... this of course is in american... thanks
M3 screws. They don't use american screws. If you wanna use thumbscrews, the Lian Li onces work quite nicely for it as they have an M3 thread instead of a 6-32 (standard case/hard drive screw)
