right basically I have a iso of one of my dvds and its ntsc and I want to convert it to pal to work in my pal dvd players.both my ps2 and dvd players support copied discs so that isn't a problem... now I don't want to be comfused with those stupid pieces of software that google always throws up about a app that unlocks your pc drive thats not what I want at all. I want to convert the ntsc iso dvd to pal to work in a pal dvd player. so what software and links please? cheers
Unless you want to completely recode the movie I *think* your going to have to rip it into IFO and VOB files then edit them with something such as IFOedit. Not really played with anything like this myself so just guessing, correct me if I'm wrong
I think there's some confusement here: Either you want to remove region coding which as said can be done with dvd-shrink. Or even simpler using DVD Decrypter. Or else you want to reencode the movie as PAL instead of the NTSC which I absolutely don't understand since I've NEVER experienced problems playing both types in any players.
