DVD Media
Discussion in 'Hardware' started by batsman, 17 Nov 2003.
  1. batsman
    batsman the quiet one
    14 Nov 2001
    What media would you recomend for use with DVD burners
    after what the recomendations are for Data discs and Movie (even if is different media/type)
    recomendations for all types eg
    +R/RW
    -R/RW &
    -RAM
    thanks
  2. Guest-16
    Guest-16 Guest
    -RAM - noone uses this, its over expensive and hardly anyone sells it tbh
    -R - Datasafe or Ritek i use
    -RW - Datasafe again.
  3. Kermet
    Kermet [custom title]
    18 Feb 2003
    For -R I've heard good things about discs using the RITEKG..04 dye, got some on order and should get to try them in a couple of days...
