Apple DVD-region unlocking?
Discussion in 'Software' started by NoahFuLing, 9 Jun 2008.
  1. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
    Hey, so WWDC is tomorrow (today now, I guess)! I wonder what Steve will announce...:naughty:
    So is there a solution for the new MacBook Pros to unlock their DVD drives to be region-unlocked? I know that Apple and Matshita (Matsushita) are a bunch of Matsush*t-heads for not allowing the new Intel Macs to be like their PC brethren, IE, not unlockable. As far as I know, all of the old firmware hackers are out of business. I was wondering if there was a solution that I missed?
  2. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    VLC will play anything irregardless no?
  3. NoahFuLing
    18 Jun 2005
    Nope. Sucks, really. I can't get it to work.
  4. Firehed
    15 Feb 2004
    Not a whole lot of options if you can't get VLC working unfortunately. There's no OS X equivalent of AnyDVD as far as I'm aware.
  5. NoahFuLing
    18 Jun 2005
    It's not that VLC doesn't work on my computer - it just works exactly like Apple DVD Player, in that it uses up one of the 5 hardware region changes. Someone used to write new firmware for the Matshita drives, but I was hoping there was a software solution...
  6. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I am also curious about this.
    I have read that if you get an external DVD drive, you can set that to a different region then the internal one. A poor work around at best, but can anyone confirm this?
  7. Krikkit
    21 Jan 2003
    Yup, that'd work. Crude though.
    Surely someone out there has written a custom firmware without region encoding?
  8. OleJ
    OleJ Me!
    1 Jul 2007
    You can use MacTheRipper to first rip, then play. I don't know of a firmware hack.
  9. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    might not work on leopard (i'm on tiger) but if you play a dvd thru vlc, it'll ask for a region change. don't choose one. you should still be able to watch the video. when you've finished, don't make any changes on the region settings (ie. click cancel) and you'll be back where you started
  10. Cei
    Cei pew pew pew
    22 Mar 2008
    Ever since the start of the PPC G5 era, unlocking your SuperDrives has become basically impossible. I unlocked a Pioneer 106D in my revision A G5, but my revision B model came with the 109D, which never got hacked. Needless to say, the Optiarc drives in the current Mac Pro are just as stuck. As for the laptops, same deal.
    As suggested, external drives on different region codes. In my Mac Pro my top drive is Region 2, and the bottom is Region 1.
  11. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    i hate region locking but its something we need to put up with i geuss.
    yeah as said above if you can't get VLC to play it then the other option is to use the very crude method of an external dvd with the region changed on it... other than that i think you're stuck!
