Windows DVD Ripping at Max Quality?
Discussion in 'Software' started by pyro1son, 8 May 2011.
  1. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    At this moment in time im using DVDFab for ripping my DVD collection to my HDD but the quality isn't that of the actual DVD.
    Can anybody suggest how I can rip the rest of my DVD's at a better quality?
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Have you tried handbrake?
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    thats not really enough information
    do you rip it to Vob or what?
    if you rip to vob hte quality is exactly the same
    then you can use handbrake to shrink
  4. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    You could just use dvd shrink with compression turned off! Also set dvdfab to dvd9, are u keeping menus or just chopping out the main feature?
  5. pyro1son
    18 Aug 2010
    I rip it to .avi I have handbreak to convert didn't know you could use it to rip.
  6. pyro1son
    18 Aug 2010
    I just keep the main feature.
  7. Hawkest
    22 Jun 2009
    Ah, what u using to play them?
  8. pyro1son
    18 Aug 2010
    VLC and XBMC
  9. adam_bagpuss
    24 Apr 2009
    why would you rip to AVI then convert using handbrake ???
    just rip to HDD using DVD fab on DVD9 setting then using handbrake to adjust to whatever quality you want
  10. pyro1son
    18 Aug 2010
    Im ripping to .avi butthe quality is too low for me im only using hand break to convert them for my iPhone.
  11. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I prefer H264 over AVI these days. Means I get hardware decoding on a my iPad 2.
    For ripping I just use Handbreak. I use H264, constant quality RF of 20, and keep the original AC3/DTS audio for compatibility with my THX audio system. (I use different settings for the iOS devices)
    Some say to drop the RF down to 18 or so for quality. Try it and see if you notice a difference.
  12. pyro1son
    18 Aug 2010
    H264 sounds like a good idea and ill give handbreak a try for ripping!
  13. pyro1son
    18 Aug 2010
    Ok now i also need a DVD ripping software as i cant get handbreak to rip and DVDFab has run out now.
    Any suggestions?
  14. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    DVDShrink is free, but you'll still need something like AnyDVD to remove any protection.
  15. pyro1son
    18 Aug 2010
    Does VLC play.VOB?
  16. Hawkest
    22 Jun 2009
    Xbmc plays vob files not sure on vlc!
  17. pyro1son
    18 Aug 2010
    Yep vlc does just tried it!
  18. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Use MakeMKV to rip file and then use Handbrake.
    I can get quality just as good as dvd but with reduced file size.
  19. Walibe
    Walibe What's a Dremel?
    24 Oct 2002
    I use DVDFab to rip the DVDs/Blu Rays and DIVX Plus Converter to to change to DIVX for the PS3, and I'm doing rips within DVDFab fpr iTunes although Quicktime Pro does a good job.
  20. Hawkest
    22 Jun 2009
    How long does that process take for say an hour and 40 minute film?
