Windows DVD Ripping at Max Quality?
Discussion in 'Software' started by pyro1son, 8 May 2011.
  1. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    standard film takes about 20 minutes on my i5, 3hours on my atom using handbrake (i did it once just for the sake of seeing how slow it is). for those with nvidia gpu mediacoder nt cuda may be worth a look, can't control it quite as much as handbrake, but outputs a good quality file in less time, which is great when you are doing a lot of films. it also has a 'watch' folder to just dump your files into and automatically ques them to be transcoded. it is also freeware.
  2. adam_bagpuss
    24 Apr 2009
    DVD Fab is free for rips ONLY
    rip to HDD then using handbrake to convert
    there is NO NEED to rip + convert then convert again !!!
  3. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    MakeMKV does the lot, all my library is ripped using this. Occasionally you'll get a protected disc that'll not play ball, in which case use DVD Decrypter first to extract, then MakeMKV to encode.
    Quality is great, especially played back via WDTV Live on a 50" Panasonic telly.
  4. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    I think were all getting confused here. I was using DVDFab to rip the DVD to a video file. But the quality was poor and as I now realize it was because i had the settings to go to .avi files instead of H264 which was why the quality was poor.
    But now the trial DVD Rip feature on DVDFab i have no way of ripping but to copy to a unprotected VOB folder and then use handbreak. Which does produce a good quality but takes dam forever.
    I am now contemplating paying for DVDFab because im going to need convert all my DVD's to files before September when i go to uni.
  5. adam_bagpuss
    24 Apr 2009
    my point is WHY. There is no need to do that at all. I use DVDfab 8 to rip a DVD to HDD. It rips in RAW format so they are all .vob
    I then use handbrake to convert it to what ever i want. in my case is convert to .mkv (H.264 codec with CQ of 17)
    Its the best way to do it although does take time my i7 920@4Ghz takes about 10-15mins to convert a 2hr film.
    if you want quality and control over it thats the way to do it.
  6. pyro1son
    18 Aug 2010
    That is what im doing now but originally i was using a trial of DVDFab DVD Ripper and it was a single operation from DVD to a watchable .avi file (as i didnt change the settings to H.264)
  7. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    What are you using to play the file?
    If you have something like the WD TV Live you could just use MakeMKV to get an MKV file that is perfectly playable and all in one easy step.
    You would only need to use Handbrake then if you wanted to shrink the file size while maintaining quality.
  8. Xir
    Xir Modder
    26 Apr 2006
    I used to use DVDshrink without compression, quality over size cheesecake:p...for dvd's those 5 GB are worth it. Been a few years though.
    I've switched to only watching Blurays so no more ripping (no drive) :D
  9. adam_bagpuss
    24 Apr 2009
    quality and size Cheesecake
    DVD rip then handbrake to .mkv in H.264 codec with CQ @ 17 with a few other settings makes 2hr film around the 2GB mark and look indistinguishable from DVDs
  10. NigelT
    NigelT What's a Dremel?
    30 Apr 2011
    PS3 won't play mkv's though will it?
  11. adam_bagpuss
    24 Apr 2009
    no but you could use MP4 as the container and use H.264 still i just prefer .mkv as its more flexible.
  12. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    ^ MKV allows chapters, MP4 does not. So if you are using .264 and mp4 with a wdtv media player you have to fast forward etc. That's why I use mkv. Or at least that's been the case for me so far.
  13. law99
    law99 Custom User Title
    24 Sep 2009
    I use dvd decrypter and dvdx. I'm not bothered by chapters or anything like that, so avi is just the ticket.
  14. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    This guy talks sense:rock:
    ( i do exactly the same )
  15. Xir
    Xir Modder
    26 Apr 2006
    Compression is interesting for blurays or handheld devices, otherwise...the TB is so cheap, why bother?
  16. adam_bagpuss
    24 Apr 2009
    i compress because it means the difference between
    6GB uncompressed DVD = ~160 or so films on a 1TB HDD
    2GB compressed film = ~500 or so on a 1TB
    with no noticeable loss in quality you cramming an extra 340 films in the same space
    now ive got around 300 films that im slowly converting so i either pay £80 for a 2x 1TB (RAID1) or pay £160 for 4x 1TB
    thats why - saves me money, space and power
  17. NigelT
    30 Apr 2011
    What Handbrake settings are people using for playback on PS3? Do you usually keep the original screen resolution?
  18. adam_bagpuss
    24 Apr 2009
    well i use this:
    note ive only listed settings ive changed from default
    container: mkv but for PS3 just use MP4
    Anamorphic: Loose
    Video codec: H.264
    constant Quality: CF@17
    subtitles: forced ONLY
    reference frames: 3
    B-frames: 3
    Adaptive B-frames: Optimal
    subpixel motion estimation: 7
    thats it
  19. Xir
    Xir Modder
    26 Apr 2006
    Ah, well in raid everything doubles I guess...
    Then again, the time spent converting these 500 movies should have a certain value as well.
    for me, having ten days of uninterrupted 100% encoding or spending 50€ on a 2TB drive...different choice than yours :D
    But you're right, for a collector, it makes sense
  20. adam_bagpuss
    24 Apr 2009
    handbrake does batch encoding so i can put it on when i go to work when i get back it should have blitz'd through up to 30 DVDs.
    i never do that many at once but if i needed to i could without it interfering with gaming or PC use.
