Windows DVD streaming over wireless network?
Discussion in 'Software' started by OneSeventeen, 23 Apr 2005.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    Right now I have two laptops and a desktop pc all on the same network. Is it possible to store DVDs on my main rig and view them over the network with my laptops?
    (This is assuming I have DVDs that are allowed to be backed up to a personal HDD, like some indie films.)
  2. bwgames
    bwgames Minimodder
    6 Dec 2004
    I've done this, but with divx files...
    you might be able to use Windows Media Encoder to stream media to mediaplayer on the laptops, but dunno if/how it works with DVDs, you might have to end up converting the dvd to one massive mpeg2 DVD file...
    I've used the above method with divx/avi/one file movies successfully.
  3. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    yea sure
    as long as you've got a strong connection and a player that can play files directly off the drive
    powerdvd and zoomplayer i know for sure can do this :)
  4. Fusen
    Fusen What's a Dremel?
    17 Jan 2004
