I am trying to find a free app to do this. most of the stuff i have found are trials. others require anydvd or dvddecrypter and you cant download either anymore.
You can download dvd decrypter: http://www.mrbass.org/dvdrip/SetupDVDDecrypter_3.5.4.0.exe Second google link... I find dvd decrypter and videora ipod convertor the best combination.
Super should do it. http://forums.bit-tech.net/showthread.php?t=121144 Or you can use dvdshrink to rip a DVD for you, just dont select compression.
Videora. http://www.videora.com/en-us/Converter/iPod/ I think you might need DVD Decrypter to use it first. PM me if you can't find it, since I have it hosted somewhere password-proteced (so I don't need to keep CDs everywhere) and will send you a link if you need it.
Videora works good. Thanks. One problem. You know the subtitles for translation of alien languages (IE Watto in Star Wars Ep I) is gone after i decrypt it in dvddecrypter even if i leave ALL the subtitles. Any suggestions or am I just out of luck?
