Modding DXF cutting in the UK? Can anyone help?
Discussion in 'Modding' started by Mojo, 15 Aug 2023.
  1. Mojo
    Mojo Multimodder
    18 Nov 2011
    Hey Folks.. i have a small file that I am looking to get cut - but it seems of the companies I look to want to have hundreds done at a time - I need 1 maybe 2 :)
    2mm Stainless. - 180.00 x 124.00
    I've the DXF file :)
    Can anyone help?
  2. Cheapskate
    13 May 2007
    Any tech/trade schools nearby with a waterjet cutter?
  3. Mojo
    Mojo Multimodder
    18 Nov 2011
    I did wonder that.. but after reaching out to a couple - had no reply... :( *sobs*
  4. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
  5. Mojo
    Mojo Multimodder
    18 Nov 2011
    Ahh cheers! i'll give them a buzz!
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    I'm also looking at some 2mm stainless cutting in a similar size. Let me know how it goes with you as I'm shopping for potentially a better price than the one I have already.
    £20 + shipping for essentially GPU backplate sized. Not sure if that's inc or ex VAT though.
  7. M_D_K
    M_D_K Modder
    3 Apr 2002
    Depending on your time frame I just dropped a ton on a new Laser that is being installed in the next couple weeks :).
    big boys toys time :).
    adidan and Arboreal like this.
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    I do need something else doing actually.. Ill ping you :)
  9. Arboreal
    21 Jan 2011
    I can recommend @M_D_K's metal cutting services. He cut a couple of sets of alu panels for David and I for the DIY BIG560 cases we got from a guy on SFFN.
    adidan likes this.
  10. M_D_K
    M_D_K Modder
    3 Apr 2002
    Now equiped with a new Laser for even thicker material, anyone need some 30mm mild steel plates ? lol.
    Arboreal likes this.
