Networks Dynamic Redirection
Discussion in 'Hardware' started by Sagegoku666@hotmai, 16 Feb 2005.
  1. Sagegoku666@hotmai
    Sagegoku666@hotmai What's a Dremel?
    16 Feb 2005
    I was wondering if there was any free way to take my existing domain (registered and hosted) and my existing home server (using apache) and to make a dynamic redirection page.
    I want to put a file on my webserver called aaa.jpg, then send someone to www.lexpu.com/???/aaa.jpg, and the script will replace the www.lexpu.com/???/ part with my IP.
    Currently i have to send them a link to my IP, or make a redirection page for everything i want to host at my server than i want to send to people.
    I've already searched around dynDNS.org, but the service they offer costs money or I have to use their domain.
    Basically, I want to put file x on my server (http:/124.124.124.142 i dunno my IP) and link to lexpu.com/???/x. I dont know the ??? part- im not very knowlegable in Javascript.
    Thanks in advance to any help
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    it's possible with mod_rewrite, but I don't know how to do it
    check out apache's manual on mod_rewrite
  3. Sagegoku666@hotmai
    16 Feb 2005
  4. Bruno_me
    30 Mar 2003
    that part of apache is used to do exactly what you described, so using that modules, you can do what you wanted to do
  5. trigger
    trigger Procrastinator
    22 Mar 2004
    I think he's saying the server hosting lexpu.com is not his, so he can't do apache stuff on it. I guess you could use a redirector meta tag like this:
    Code:
      <meta http-equiv="REFRESH" content="5; URL=http://123.123.123.123/aa.htm">
    edit: Ah, but that wont work with the .jpg files though of course...
  6. Sagegoku666@hotmai
    16 Feb 2005
    Exactly: Lexpu.com isnt my apache server. Its some other hosting thing that i pay for. My IP address isn't in a DNS. The Meta Tag solution would work, except it doesn't work for all files and I'd have to make an html page with that for each page i want to redirect to. Isn't there some way where its smart enough to parse the URL and redirect using a dynamicly changeable (Like it loads my IP from a source file so I only have to change one thing if my IP changes) Address?
    Lets say theres a file called ip.txt that contains my IP
    I want it to be able to take something like www.lexpu.com/??/aa.htm, say ooh, thats in the /??/ directory. Ok, lets redirect to http://[the IP in ip.txt]/aa.htm
    Or, www.lexpu.com/??/newfolder/aa.htm would go to http://[the IP in ip.txt]/newfolder/aa.htm
    aa.htm is just an example. It could be asdasd.jpg, or w/e. The whole point is i don't have to upload to lexpu.com and I don't have to type my IP each time I want to give someone something (www.lexpu.com/??/filename.extension is alot easier that http://255.255.255.0:81/filename.extension since that 255.255.255.0 could be anything)
  7. RTT
    RTT #parp
    12 Mar 2001
  8. Sagegoku666@hotmai
    16 Feb 2005
    I have content on lexpu. can i make it so it takes lexpu.com/??/aa.htm and makes it [ip here]aa.htm? I still want my other stuff on lexpu.com (such as the lexpu.com/programs/ directory)
  9. Atomic
    Atomic Gerwaff
    6 May 2002
    So you only want say
    lexpu.com/move/aa.htm -> #IP#/aa.htm
    Your best bet is prob a php script id guess...
  10. RTT
    RTT #parp
    12 Mar 2001
    yep, just put the .htaccess file in the /??/ directory..., such as lexpu.com/redirect/ so anything @ lexpu.com/redirect/[ANYTHING HERE] is redirected :)
    Or you could just alter the htaccess file to read:
    Code:
    RewriteEngine On
    ReWriterule ^redirect/(.*) http://your-ip-here/$1
  11. Sagegoku666@hotmai
    16 Feb 2005
    k! works great. thanks so much
  12. RTT
    RTT #parp
    12 Mar 2001
    No problem :thumb:
