Motors Dyno Sheet from yesterday..
Discussion in 'General' started by Bartop, 22 Apr 2006.
  1. Bartop
    Bartop What's a Dremel?
    12 Feb 2003
    Here's mine - done yesterday at Powerstation in Tewkesbury. I'm afraid I have no clue about these things so if you guys could give some pointers on what looks good/bad that would be great.
    It's a MY06 2.5 FXT - engine mods are 3" Milltek turbo back system, VF39 Turbo, 255lph Walbro Fuel Pump and Tek3 remap. Unfortunately I couldn't get the upgraded intercooler on so had to stick with the oem one but plan to upgrade asap.
    Cheers
    Pete
  2. Valo
    Valo Minimodder
    11 Aug 2004
    holy hell... 420nm of torque... thats incredible!
  3. Bartop
    12 Feb 2003
    For Uk peeps I think that coverts to about 310 Lb-ft
  4. Guest-16
    Guest-16 Guest
    Yea you wanna be driving at around 4k rpm which gives the best returns, but you're good all the way up to 5.3ish :D
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    How much does it weigh?
  6. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Tht intercooler should do very well. You have enough tourque to get those weels burning ruber.
    And you dont want to drive at 4k range. Your shift points should be around 4 if you want better economy. and always keep it one gear ahead if you dont want to dump unecesary fuel out.
  7. ultrastapler
    ultrastapler What's a Dremel?
    30 Oct 2003
    ^i don't think fuel economy is a primary concern
  8. MonkeyTurnip
    MonkeyTurnip What's a Dremel?
    23 Aug 2005
    youve got a nasty flat spot between 4k and 5k, it looks liek fueling, what did the person doing the testing say, get the FMIC on there ASAP. are you running stock injectors? have you had the ECU remapped? that will probably sort it out for you
    other than that it looks good.
    Edit after seeing mod list:
    get the ECU Remapped as soon as the FMIC goes on and jet uprated injectors, you'll see a big gain
  9. Bartop
    12 Feb 2003
    Hi - thanks for pointing that out - I see that now, will look out to see if that's evident on the road !
    Have got 550 injectors which should be fine for up to 370 + so don't think thats an issue - I did get an uprated fuel pump though..
    Will get it remapped though with the new Intercooler on..
    Thks
    Pete
