Other E-Cigarette
Discussion in 'General' started by kenco_uk, 6 Apr 2013.
  1. kenco_uk
    28 Nov 2003
    Does anybody have any recommendations for an e-cigarette?
    I'm giving up smoking but need an equivalent fix. I'm currently using a Genesis 510 and it gives me something to do but I'm not getting the flavour (perhaps I'm not doing it right), although I think it's giving me a nicotine hit (I'm not crawling up the walls, at least not yet). It certainly delivers a hit to the throat!
  2. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    With the kit you have make sure you take a slow steady draw, it might help
    I steer clear of the cig-a-like type now. Good place to start but lacking in flavor as you have found out.
    You could try a Boge cartomiser, should be a bit better but for real flavor you need to get a rebuildable atomiser using good quality silica wick or a stainless steel mesh.
    The last option with mesh can be a bit fiddly and frustrating until you get it right.
  3. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    I don't understand the e cigarette it gives you same thing as a real cigarette you can just use it in a a lot more places!
  4. ThirtyQuidKid
    11 Jun 2010
  5. M_D_K
    M_D_K Minimodder
    3 Apr 2002
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    @M_D_K
    nicotine is a stimulant, by itself (as in not paired with smoking an actual cigarette to get nicotine) it's around the same as caffeine healthwise
    that said, i'm not sold on the total 'healthiness' of e-cigarettes. there aren't any real studies that show that propylene glycol and vegetable glycerin are safe to vaporize and inhale as far as i know
  7. ThirtyQuidKid
    11 Jun 2010
    That's why I said "almost" in my post.
    @ docodine you are correct there are very few studies at the moment so It's a waiting game.
    A couple of studies and info in no particular order
    http://www.biomedcentral.com/content/pdf/1471-2458-11-786.pdf
    http://ash.org.uk/files/documents/ASH_715.pdf
    http://informahealthcare.com/doi/abs/10.3109/08958378.2012.724728
    http://www.healthnz.co.nz/ecigarette.htm
    Hope the direct links are OK it all public domain.
    Needless to say stopping smoking or not using e-cigs are the preferred option but if you have to is it better to use a product containing over 4000 dangerous chemicals or on containing 10 potentially harmful chemicals..
