Case Mod - In Progress e-H2O pt.1
Discussion in 'Project Logs' started by Goatee, 15 Jun 2019.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    I'm trying something a bit different this time, my inspiration came a while ago after reading about the development of a heart in a box.
    I acquired an e-GPU and this made me think this would be pretty cool to do the same with an e-water loop to provide cooling on the go for a small water cooled PC that could be plugged into a different loop when at home.
    It remained a concept floating round in my mind until i spotted some medium sized safe cases reduced in my local DIY shop.
    [​IMG] = [​IMG]
    I acquired a couple of boxes with the intention of using one as "the heart in a box".
    I tried a number of different methods to glue a frame to the case, but being polypropylene nothing sticks, its like the opposite of excrement to a blanket.
    I settled on drilling four small holes in the base of the case where the moulded feet are. I could then add o-rings to retain the waterproofing.
    I then feed M6 screws from the outside to secure the large metal plate to the base of the case.
    I was originally going to use a nut on the inside to secure the plate, but I received an early fathers day present of a nut riveter.
    This allowed me to put a threaded insert into the metal plate to attach the screw to. I was amazed at how well this worked and how secure the plate is.
    [​IMG].
    I offered up the radiator to the plate to mark where it will fit.
    The fans sit just under the case lip.
    Not pictured is the fact I have added 8 x 10mm standoffs to the radiator to give the radiator clearance from the retaining base plate.
    I drilled some holes to match the standoffs to allow me to firmly attach the radiator to the base plate.
    I added a couple more components to show the intended plan.
    I'm awaiting a temp / flow monitor being delivered tomorrow I can then test the quick disconnects I am trialling to make sure its suitable (and don't restrict flow too much). More in the thread here: Link
    Thanks to @Yaka @edzieba @cobalt6700 @The_Crapman for the guidance on the QDC fittings.
    cobalt6700 and The_Crapman like this.
  2. Cheapskate
    13 May 2007
    This travel setup won't pass through any airports, right?
    Goatee likes this.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Oooooooo. This looks good. I'm not sure I can take any credit for guidance though. I just saw something shiny and wanted in :naughty:
    Goatee likes this.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    No way that’s getting on a plane. Liquids restrictions aside try to explain what it is to the people at security wouldn’t be a fun experience.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Sometimes all you need is someone to confirm you are (or aren’t) crazy.
    The_Crapman likes this.
  6. Goatee
    Goatee Multimodder
    19 Apr 2015
    Update time!
    My friendly amazon guy arrived mid afternoon so once I had completed my fathers days activities (shout out to all the dads) and put the boy to bed this evening I retired to the garage to plumb some stuff up!
    Here is the setup:
    Its pretty cool being able to remove the base plate and work on the loop. Everything is so easy to access.
    The base line setup is:
    • 1 x 240mm Rad, 30mm thick
    • EK-XTOP SPC-60 PWM - Plexi
    • Aquacomputer Waterblock for Aquaero 5 (its not needed but gives a really nice return feature to firm the whole loop up)
    • Thermaltake Pacific Tf1 Temperature and Flow Indicator
    • Various fittings and tubing
    I achieved a fairly stable 136 L/h which equates to approx 0.6 G/m
    Next I added the QDC in (these ones):
    Getting around 115-120 l/h which is a drop of 15 L/h or 0.06G/M. It was more difficult to bleed using my T-line but still looking ok.
    So how do they work as a quick disconnect?
    Pretty damn good!
    I'm trying to source a couple of QDCs from Alphacool and Koolance to do a comparison. If anyone has any in a draw and fancies letting me borrow them for testing please drop me a PM. After a bit of testing versus watercooling specific fittings I will decide where to go next.
    Not a bad test.
    Dr. Coin and The_Crapman like this.
  7. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    I follow with interest
  8. The_Crapman
    5 Dec 2011
    Excellent news! Will be interesting to see a comparison to the Alphacool and koolance ones, but they seem good enough. Won't really make a great deal of difference to temps.
  9. Cheapskate
    13 May 2007
    I saw that res and wondered how the heck that would fit in the case. I think I'm still half asleep.
    Goatee likes this.
  10. Goatee
    Goatee Multimodder
    19 Apr 2015
    Just for filling as currently got a T-line arrangement.
  11. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Thumbs up for testing and sharing. :thumb:
    Beefy fittings.
    Goatee likes this.
  12. Goatee
    Goatee Multimodder
    19 Apr 2015
    A set of Alphacool Eiszapfen arrived. They are a lot smaller!
    Here's the result of the Alphacool fittings
    However the amount of fluid after a disconnect is more significant and the disconnecting process feels less "secure" which is quite hard to quantify.
    I reset the loop again and am back to 136L / M with no QDC's, so comparing apples to apples looks like the Alphacool fittings are about 3 l/m or ~20% less restrictive.
    The Flowfit fittings are quite a bit cheaper in the UK and seem to seal better, but are bigger and more restrictive. So I'm weighing up which solution I go for. I could potentially use a thicker rad with the alphacool fittings, so I might try that out then make a decision.
    Thoughts?
  13. Goatee
    Goatee Multimodder
    19 Apr 2015
    I didn't realise how beefy until the alphacool ones arrived.
  14. The_Crapman
    5 Dec 2011
    Wow. I don't think they're beefy, they're full on heardy! It would depend a bit on how many you need, a couple is too much of a saving, half a dozen or more and it starts adding up. The Alphacool ones are 'neater', but there's something to be said for the brutality of the other ones that might fit the build better.
    Goatee likes this.
  15. Goatee
    Goatee Multimodder
    19 Apr 2015
    I like the look but I have gone with the flexibility of the Alphacool fittings. I have been discussing the issues around airflow clearance and might change the radiator up. I rally want to put a res in the loop rather than a T-line, so might mix it up a little.
  16. The_Crapman
    5 Dec 2011
    Res will help with the thermal capacity of the loop for sure and if it opens up some options then probably for the best.
  17. MADPC
    MADPC Minimodder
    10 May 2020
    interesting job any news?
