E6750 FSB 1333 on P5B-E
Discussion in 'Hardware' started by dutchcowes, 13 Jul 2007.
  1. dutchcowes
    dutchcowes less is more
    2 Feb 2002
    Hi all,
    Anyone knows if this board supports this one, I know it must do accoording to some bios info, but want to sure be put one on order.
    Thanks,
    :thumb:
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
  3. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Nope, that's a no go. You need a P35, G33 or nForce 680 chipset mobo. You could possibly get it to run (if the board will boot with it), but I think it will only run 1066 x the cpu default multi. You'd have to OC just to get to default clocks.
  4. chrisb2e9
    18 Jun 2007
    yeah thats what I thought.
    The board will do quad core though so you could just get the Q6600 when the price drop happens. or the e6700 since its the slower fsb of 1066.
    Or if you really want that processor, like spqqky said, get something like an asus p5k.
  5. Krikkit
    21 Jan 2003
    As above, you'll have to OC to get to stock speeds, but as these boards can often see nearly 500FSB, it's not a big push to go from 266MHz to 333MHz.
  6. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    The box of my dead P5B motherboard clearly states that it supports '1333mhz fsb future cpu upgrade'
    What's that all about then?
  7. Krikkit
    21 Jan 2003
    Then the P5B-E uses different chipsets to yours/cheaper silicon - this is the specs page for the P5B-E, and it's definately not got out-of-the-box 1333MHz support.
  8. Silver Shamrock
    19 Sep 2005
    Ahh right. Mine is the P5B-E Plus and has a black PCB. I'm going to start another thread about all of this 1333mhz support, as i'm a little confused myself.
  9. dutchcowes
    2 Feb 2002
    thanks guys, I have got the standard version no black pcb. Will get a 6700 or quad core when price drops. Atm my 6400 is still running ok though, can not believe how quick mobo,chipsets and cpu speeds are changing. Gone are the days of overclocking a K6-2 450mhz to 550mhz and feeling like a overclocking god:)
  10. Silver Shamrock
    19 Sep 2005
    Looks like you CAN run the new intel cpus afterall with your board. There has just been a new BIOS with the 1333mhz cpu support
    Check out http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-E for the updated cpu support list.
  11. dutchcowes
    2 Feb 2002
    cool,I wait for a while before flashing my bios with this latest one, anyway good news.
    :clap:
