Hardware Early Look: Asus P6T Deluxe
Discussion in 'Article Discussion' started by Guest-16, 21 Aug 2008.
  1. trig
    trig god's little mistake
    10 Aug 2006
    in the words of quagmire...anybody got a towel...
  2. SlickGnome
    SlickGnome New Member
    2 Feb 2007
    Depening on price, I think this may be my next upgrade... Gotta love teh Asus
  3. johnnyboy700
    johnnyboy700 Active Member
    27 May 2007
    If this is anything less than £300 I'll be surprised.
  4. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Well were almost into Q4 so sometime within the next 2 weeks and I guess we will be seeing Nahalem.
    That's sweet and makes my laptop all the more acceptable for a few more weeks. Not seeing pre-order yet for the CPU's yet which is dissapointing. Most mobo manufacturers have stated Q3-Q4 so we should be seeing action soon.
    Cant wait to see the BT Nahalem reviews!
  5. Horizon
    Horizon Dremel Worthy
    30 May 2008
    Someone hasn't been buttsechs'd by them. I bought a xonar and let's just say the love stops at vista 32.
  6. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Eh, go for a pair of 4870's in crossfire. Then you won't be locked into an Nforce.
  7. samkiller42
    25 Apr 2006
    I don't like AMD/ATI, and already own two 8800GTX's, and certainly don't want to buy 2 amd cards.
    Sam
  8. Guest-16
    Guest-16 Guest
    ??? The Xonar works perfectly in Vista 32.
  9. theoone
    theoone theoone
    26 Aug 2008
    I too would like too see all IDE deleted and replaced with right angle SATA
  10. theoone
    theoone theoone
    26 Aug 2008
    Thats how i want it to be
    What do you think guys?
  11. h4x3r22
    h4x3r22 New Member
    30 Aug 2008
    Can not wait until this goes on sale. This and a Nehalem processor will be a match made in gamers' heaven. I hope bit-tech gets a bit more info and maybe a test or two soon.
  12. Guest-16
    Guest-16 Guest
    Three PCI? Oooold. Phased out.
    Plus you've more southbridge SATA ports than there are actually used, however I wish Intel would up their ICH to 8/10 already - it's been 6 for years.
  13. theoone
    theoone theoone
    26 Aug 2008
    yes i agree PCI-E would be better but still its just a dream for now
  14. Casper42
    Casper42 New Member
    6 Oct 2008
    The posts in this thread are a tad old, but to close the loop on this topic...
    ALL X58 Boards with QPI (Memory Controller in Processor) get a free pass to run SLI from nVidia.
    nVidia decided they didnt want to (or couldnt in time) design a chipset for the higher end Nehalem Processors, so they tried to force OEMs to buy an nForce 200 chip to put on the motherboard.
    The OEMs pushed back and since nVidia didnt want their GPU sales to plummet, they gave a free pass to X58 machines.
    No guarantee that P55 or G55 or whatever the mainstream counterparts will receive the same. But those will likely not use QPI and will use northbridge to control memory anyway, so nVidia may have a product in that market that will support SLI.
    So, this motherboard above can run SLI or CROSSFIRE.
    Only downside is the layout ASUS chose prevents a Triple SLI as most cards from nV that support Triple are Dual Width and there is not enough room next to the 3rd PCIe x16 slot on this mobo.
    -Casper42
    PS: The main reason I added this is because this mini review was the very first hit on Google for "asus p6t".
    Want to make sure all are informed.
  15. [USRF]Obiwan
    [USRF]Obiwan New Member
    9 Apr 2003
    Plus:
    Now this is how I would want it! No more FDD and even IDE, enough sata connectors to hit the 10T mark
    Plus/min:
    The power connector is on the bottom. This is probably for the new style PSU placement at the bottom.
    Min:
    The connectors for exta usb, firewire etc are totaly in the wrong place. Now you have to cross cables over the motherboard to the rear brackets for exta usb brackets and such...
  16. kenco_uk
    28 Nov 2003
    PSU at bottom, EPS at top. How mad is that?
    Might have to think about a pci-e sound card soon!
  17. [USRF]Obiwan
    9 Apr 2003
    good find, mad indeed! :duh:
  18. [USRF]Obiwan
    9 Apr 2003
    Other views:
    rumor goes there is a SAS controller on board.
    Also:
    Worldrecord 1M-benchmark SuperPI is in Dutch hands!
    Running a Core 2 Duo E8600-cpu on 6626,2MHz!
    FSB running on 662MHz on a unmodded DFI lanparty P45-T2RS motherboard
    06.843 seconds!
  19. zoom314
    zoom314 Member
    10 Jun 2003
    Looks ok, But I'm not sure of that big heatsink between the slots and the cpu, As I use tower heatsinks, So MSI's Eclipse (X58)motherboard is looking attractive to Me, If The P6T Deluxe had heatsinks as thin as they do in the P5K Deluxe, Then the P6T Deluxe would be perfect to Me. Jmicron sucks, But I can ignore suckage for compatibility and so I lose a bit of Marvell as a result.
  20. zoom314
    zoom314 Member
    10 Jun 2003
    Except for Your first link, All the rest have been taken down and are saying "No Deep Linking".
    And Yes there's a Marvel SAS controller for the Orange ports that can in a pinch be used for SATA too.
Tags: Add Tags
