Hardware Early Look: Cooler Master Sniper
Discussion in 'Article Discussion' started by Guest-16, 29 Aug 2008.
  1. Skepsis
    Skepsis New Member
    16 Aug 2008
    The dust, think of the dust!
  2. h4x3r22
    h4x3r22 New Member
    30 Aug 2008
    I like the idea of cooler master taking a focused interest in gamers. This is a rough start but i'm sure a few trial and errors will produce a creditable case that some fans will enjoy. As far as this case, it looks durable and great for mods but I can see that only a select few share those interests without other perks. Good Start CoolerMaster.
  3. sl1xx
    sl1xx New Member
    12 Apr 2006
    that case would be loud there seems no insulation just mesh
  4. GavX
    GavX New Member
    5 Apr 2008
    I see this case is like Marmite... love it or hate it :D I think its cool myself, I wouldn' want one, but its still quiet cool
  5. tonschk
    tonschk New Member
    31 Jul 2008
    Very nice and beautyful case I think this is the most perfect case ever made,I must get this case :thumb:
  6. Major
    Major Guest
    Looks like ****.
  7. steve30x
    steve30x New Member
    31 Aug 2008
    I lke that case but would rather have the power , reset , HDD light and Power light on the front of the case instead of the top because I have my computer on my kitchen table. I would also like to see them make a version of the case where it would be possible to install a 240mm radiator on the roof of the case and someplace to hide the pump and reservoir for watercooling. Other than that I love the look of it and I love the way they put a hole in the rear of the motherboard tray to access the rear of the CPU area. It would make it slightly easier to install a CPU waterblock.
  8. Bluefan
    Bluefan test 123
    25 Feb 2005
    The only thing that stands out in a negative way is the fan controller knob. I messes with the clean look. If that panel is somehow "cleaned" to be far more subtle, I'd love the case. And never mind a mobo tray, the hole in the back isn't even on many removable trays, so it's a big plus. and we're all skilled enough to put some hardware in. I've had far worse than not a removable tray. And a watercooling loop makes a tray useless unless you insist on removing the blocks each time you upgrade you ram...
    And the front actually looks good.
  9. MeltedDuron
    MeltedDuron New Member
    31 Aug 2008
    I'm really not liking that case... its a half decent layout, but it looks like it was designed as a star trek prop! I think that CM really need to reissue the ATCS cases. if they modernized it a little, I'm pretty sure that an ATC 110 reissue could be the greatest case of all time. it seems like a few years ago CM and Lian Li were doing the same thing, and then CM got bored of making the most beautiful cases around and decided that they'd go all thermaltake on us and started to use steel and plastic excessively in their cases. If theres anyone from CM R&D here, please take note of this post, what happened to the masters of aluminium?
  10. steve30x
    steve30x New Member
    31 Aug 2008
    What are you on about? I havent had to remove the blocks when I upgrade my ram. The only thing I want watercooled and have watercooled in my computer is the CPU. I dont need to remove the block from the loop each time I need to change ram. So I dont understand what your talking about.
    Also I like that knob / button for the fans but maybe to make it look better (for some) maybe have it so that you can recess it into the panel with a press and then press it again to make it come out of the panel so you can use it.
  11. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    well it looks like it will have some great ventilation if you want to do a passive type system.
  12. Amon
    Amon inch-perfect
    1 Jun 2007
    Like I said, I'm pretty sure these open-air panels defeat the purpose of directed air flow. It's just for showing off.
  13. HourBeforeDawn
    26 Oct 2006
    thats why I stated a passive system as any fan placed other then directly focused at the item being cooled would have no channel or flow as u put it.
  14. tonschk
    tonschk New Member
    31 Jul 2008
    Yes I agree with you , I avoid cases made of alluminium , alluminium is a weak metal , therefore I am looking only for cases made of hard steel :thumb:
  15. HourBeforeDawn
    26 Oct 2006
    please tell me that was just a bad joke???
  16. tonschk
    tonschk New Member
    31 Jul 2008
    Dont you know Alluminium is a weak metal , you can check this info in every chemistry book
  17. HourBeforeDawn
    26 Oct 2006
    wow umm okay so are u failing chemistry? or were u just dropped on your head as a child? seriously lol hmm sure I guess if aluminum foil is the only form of aluminum you have encountered then ya its pretty weak but billet aluminum is a very strong light weight metal, lol hell they make jets from it and car rims, engine blocks and other industrial parts and well I could go on and on but I dont want to overload you right away needless to say your pretty misinformed about the properties of aluminum.
  18. tonschk
    tonschk New Member
    31 Jul 2008
    I have had bad experiences with ball bearing fans therefore I try to avoid ball bearings
  19. Haramzadeh
    Haramzadeh Son of Sin
    8 Sep 2008
    I got a CM Stacker 832. It looks 10 times better than this.
  20. tonschk
    tonschk New Member
    31 Jul 2008
    Yes I agree , I avoid cases with removeable motherboard tray , removeable mobo tray adds unnecessary complexity , increase the cost , and the case become weaker and less solid , therefore I only buy cases with the mobo tray fitted with solid permanent rivets to the frame
Tags: Add Tags
