Hardware Early Look: Gigabyte GA-EX58-Extreme
Discussion in 'Article Discussion' started by Tim S, 10 Oct 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    time to drop ide and ps2 across the board but especially on an "Extreme" mobo
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    i don't like the clear cmos button around the back. imagine your reaching back to unplug your audio jack cause you need your speakers and.... uuuuuuups....
  4. The boy 4rm oz
    10 Apr 2008
    I think they should actually keep the IDE connector, at least one. A lot of people still use IDE drives and will continue to because they do just a good a job than SATA drives for most people. But I do agree with you Denis on the PS2 connectors, they really should be gone by now.
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    we've had this discussion before methinks, but on a 300+ pounds board with a full TEN sata ports, is it really that strange to expect a user to toss in 15 pounds for an el cheapo SATA drive? Most of the people that use this will go the whole 9 yards and go for BR-drives anyway.
    Typical price for a system like this:
    300 mobo
    600-1000 CPU
    300 GPU (and that's without going SLI/CF)
    200 storage
    150 case
    150 PSU
    That makes at LEAST 2000. A simple SATA DVD drive would drive up cost by a grand total of 1% :eeek:
    Spring cleaning, dump the connector!
    Otherwise, sexy sexy board! :hip:
  6. kenco_uk
    28 Nov 2003
    The four J-Micron sata ports - would they be able to take a sata optical drive?
  7. Guest-16
    Guest-16 Guest
    I'm pretty sure they can, as long as the SATA device supports ACHI mode compatibility I think. I'll check when I get it.
  8. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    more i see of these X58s, the more i want one. Just want to see how the Memory overvolting thing pans out. Its realy quite worrying for such a high end chipset that the highest end memory wont work.
  9. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Anyone else thinks three RAM slots would be enough?
    Why waste PCB with three other RAM slots that will be vacant in ~99,4% of the systems?
  10. SuperNova
    SuperNova What's a Dremel?
    13 Nov 2007
    Is it just me that cant understand why they type "Clr CMOS" on the button? I mean there is clearly room to for "Clear CMOS". It allmost looks like the Memory gets a 3-Phase power unit though.
  11. Jipa
    5 Feb 2004
    The color scheme makes pandas cry. Seriously PLEASE, Gigabyte...
  12. Saivert
    Saivert Minimodder
    26 Mar 2005
    Why should a motherboard like EX58 look better than my GA-p35-DS4?
    hehehe...
    an yeah, legacy connectors must go. And where is my Unified Extensible Firmware Interface?
  13. Nature
    Nature Minimodder
    21 Nov 2005
    Who will be the manufaturer supplying draft n as standard as an ethernet!??? WHOO!!!!!!??? and when you &*(^#%! eunuchs!!!!! what gen will be "next" enough???????
  14. <Blake>
    <Blake> What's a Dremel?
    16 Feb 2007
    Will this have UD3? i skimmed over the article as it is late here in AUS, will read properly tommorrow.
  15. <Blake>
    16 Feb 2007
    never mind i looked at the picture of the mobo. this will be UD3....
  16. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    I'm an asus boy but people over at extreme forums love gigabyte and rate them as the number 1 board manufacturer, esp. for overclockers and they put asus in third with someone like msi/abit taking 2nd place. As it is i'm more and more interested in gigabyte boards for my next upgrade from my current piece o crud, the 680i chipset. Despite the god awful looks on a gigabyte, are they really that good rich?
    peace
    fatman
  17. Guest-16
    Guest-16 Guest
    Yea, but I've personally had a lot of success with Asus stuff. XS is excellent in their own way, but for the more mainstream to high end overclocker, without going extreme, either will suit. Gigabyte do do excellent BIOS' though.
    MSI is a bit more hit and miss like DFI sometimes, but lacks heavy beta support from a community.
  18. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    The board says it has "h/w RAID". I presume it is taking the piss?
    edit: just found the bit where it talk about it. IS it the case you either have two drive raid 1, two drive raid 0 or a single drive per purple socket?
    edit2: eeek! I have been rick-relixed!
  19. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    Did anyone see the pics of the board with all the stock cooling on it?
    I'm betting it weighs in over 5kg :p
  20. Guest-16
    Guest-16 Guest
    Yes
Tags: Add Tags
