A/V Earphones Wiring
Discussion in 'Tech Support' started by Strudul, 6 Apr 2014.
  1. Strudul
    Strudul ~
    31 May 2010
    Edit: Solved
    I'm trying to rewire my (Skullcandy Ink'd) earphones to a 3.5mm stereo jack, but can't work out what each wire is for.
    There are 2 separate wires that run down, one from each earbud.
    One contains red, green, copper and white wires.
    The other contains blue and copper wires.
    I'm not bothered about the mic / button.
    Looking on the internet implies...
    Green: left +
    Red: right +
    Copper and blue: left - & right -
    ...but in my case, wouldn't that mean one bud is only connected to ground, with the other not being grounded at all?
    That blob in the middle is like this. I'm assuming it's just to stop the wires pulling apart and that the wires stay separate throughout.
    Cheers
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    What was the original jack like?
    If you cut it off yourself can you not identify the cables from the jack's pin-out and a multimeter/continuity tester?
  3. ferret141
    18 Oct 2010
    *double derp*
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    my gut would go with green-copper for earphone red-white for mic and the mic button merely disconnects mic.
    actually, try getting a multi-meter on the red and copper then white - copper press button in each case to see if it makes open loop
    I suggest the mic and the switch use the same copper as the earphone
    seen as how the other earphone is blue-copper.
  5. Strudul
    Strudul ~
    31 May 2010
    I cut it off a long time ago and I think it probably got binned.
  6. Strudul
    Strudul ~
    31 May 2010
    Using a continuity tester...
    I can hear static in the left earphone if I put it across the blue and copper wires.
    I can hear static in the right earphone if I put it across the red and green wires.
    ..but I can't get it to beep like usual.
    Does this mean that blue is R+ and copper is R-
    and Red and Green are L+ and L- ? (how do I know which is + and - ?)
    EDIT: Just played with it until it worked:
    Blue: L+
    Copper: L-
    Green: R+
    Red R-
